> Question about stand alone...., Can it be used for this...?
post Dec 12, 2004 - 12:41 AM
Jehuty
Joined Nov 21, '04
From Central Valley CA
From what I understand, swapping a 20v into an ST also involves swapping the wiring harness.
I've never worked with stand alone, so I have a dumb question here:
Could a standalone be used to operate a 20v while leaving the stock 7A wiring harness in place?
Why or why not? As detailed an explanation as possible would not be in vain, as I promise Ill soak it all up. =)
post Dec 12, 2004 - 12:54 AM
The stock 7A plugs don't fit the 20V 4A-GE. Also, some plugs are missing, such as the VVT plug and such. If you go standalone, I'd create a custom harness or use the 20V's harness.
Lo-Fi Version Time is now: February 23rd, 2025 - 10:30 PM
