> Just a Quick Question, Lotek 3 pillar
post Dec 13, 2004 - 4:47 PM
hyp3rk1d
Joined Sep 22, '03
I searched this topic, found it but didnt get the response i was looking for... Will I be able to snap my stock Pillar out and just replace it with the lotek one or will I have to drill through the pillar thats in the car now and hold it down with a screw?? Let me know and can I see a picture if anyone has one. Thanks
post Dec 13, 2004 - 4:54 PM
shid
Joined Jan 8, '04
From LA
I believe the mold was made off a convertible, so I'm not sure if it will cover the entire original pillar.
Anyone know?
post Dec 13, 2004 - 11:09 PM
hyp3rk1d
Joined Sep 22, '03
Thanks shid.. Any1 know?
post Dec 13, 2004 - 11:42 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
It can do either. the only problem is your existing Pillar go's all the way to like the back seat area, but the lotek pillar only go's a little above the windshiled, so even if you took out your pillar and had only the lotek, you would have to cut your existing pillar for the remaining strech above the side window.
Also, just to mention this, the lotek poillar only fits smaller type guages. Which excludes any high end guages such as Apex, HKS, Greddy, Blitz etc. And leaves you with basically only autometer guages to choose from.
post Dec 14, 2004 - 9:10 PM
hyp3rk1d
Joined Sep 22, '03
so basically I should just drill into the existing pillar.... Thanks guys
post Dec 14, 2004 - 9:26 PM
orvillescelica
the mold was made off a hatches a pillar, but was test fitted on my car, which is a vert. Lotek only made it to go just past where the windshiled ends. This was fine for me, as thats where the verts one ends. So it was a direct replacement for me. But for everyone else, it extends all the way back, so you either need to cut that part off from your stock one, or just drill into your stock one and place the lotek one on top.
Lo-Fi Version Time is now: February 21st, 2025 - 1:09 PM
