> car didnt start again yerturday
post Dec 14, 2004 - 9:01 AM
Nigel
Joined Aug 21, '03
From UK Liverpool
thts twice thts happened in the last couple months, last time a guy come out and as soon as he jumped started it it worked so it must be the batt, so i got it on change but it still dont work, anyway cya hav a gd crimbo
post Dec 14, 2004 - 10:32 PM
Junior
Joined May 5, '03
From Toronto
altenator, not battery. You might have wasted your money.
post Dec 15, 2004 - 6:20 PM
Anub1s
Joined Nov 27, '03
Check your batter terminals to make sure they are all they way connected and seated all the way down on the terminal, they are very picky connectors. Mine had the same problem then we adjusted them and it worked fine.
post Dec 16, 2004 - 5:51 PM
funnyboy117
Joined Mar 9, '04
From San Carlos, CA
What are the symptoms when it doesn't start? Does nothing happen when you turn the key? Or does the engine rotate and then not start?
Lo-Fi Version Time is now: February 22nd, 2025 - 12:40 PM
