FS: 5S parts, Most of it, valve cover, manifolds etc.. |
Dec 14, 2004 - 2:31 PM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
Well I had tried this awhile ago when the 3s was first put in the car, but here it gos again.
Most of the engine is still assembled, but in no way good enough to be put back in someones car. The reason the engine was taken out and replaced (other then a 3s being kick ass) was that the third spark plug threads were more or less destroyed and so the spark plug would not stay in. This was the only problem with the engine. So a few parts I have sitting around, but not limited to are: Valve cover Intake manifold Exhaust manifold Exhaust heat shield O2 sensors Egr Valve Altenator Oil Pan Cam Shafts (with cam gears, if anyone has ever opened up their 5s it is pretty interesting. Their is only one gear powered by the timing belt and then the other cam shaft is powered by gears that sit under the valve cover.) The pistons and all the lower engine are there but I would need time to pull it apart, just let me know if you are interested in any of that. Like I said above the engine is mostly intact, with only the valve cover, cams, and intake manifold removed so I would need a little time to pull the engine apart if you want internals. All parts on the engine are unmodified, and unpainted. Here is your chance to have extra parts to try painting and polishing projects. This post has been edited by Chrobis: Dec 14, 2004 - 2:32 PM |
Dec 14, 2004 - 9:07 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
hey, i need a a part from the engine, "TVV" is a green top vacuum plug that thats right on top(or in front) of where the upper radiator hose connects to the engine. its also described on the firewall in the vacuum hose routing diagram right next to where it says (RH). If you have it let me know i'll give you $20 for it.
Dec 15, 2004 - 1:18 AM |
if you could be a little more specific that would be great, but otherwise I will check in the morning. I havnt had the 5s in for awhile so (this sounds stupid I know) but I forgot where the top radiator hose plugs in, I look at pics in peeps profiles though.
Dec 15, 2004 - 1:22 AM |
umm I looked in your profile, and saw the green thing, my setup seems to be a bit different... where you have that green hose thingy, I have a plug in, where part of my harness would plug in.
Dec 15, 2004 - 1:35 AM |
edited
This post has been edited by Consynx: Dec 15, 2004 - 2:49 AM -------------------- |
Dec 15, 2004 - 12:56 PM |
Enthusiast Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
Do you have the part that the second O2 sensor connects to? The person who owned the car before me striped the second O2 sensor and glued the sensor in place.
Lo-Fi Version | Time is now: November 24th, 2024 - 3:42 AM |
