where to run the wires |
Mar 23, 2003 - 5:39 PM |
Enthusiast Joined Mar 2, '03 From U.K Currently Offline Reputation: 0 (0%) |
Where is the best place to run the wires from the head unit, and the battery to the trunk and how do i do it.
Mar 23, 2003 - 5:55 PM |
Have your amp under the passenger's seat, and run them through the panel where the right rear door speaker is. Then around and into the trunk. I have a coupe though...
Mar 23, 2003 - 6:46 PM |
I am going to install the amp in the trunk as part of a larger install, is it easy to run the wires up through the centre console where the handbrake etc is ?
Mar 23, 2003 - 6:56 PM |
Enthusiast Joined Jan 20, '03 From Denver, co Currently Offline Reputation: 0 (0%) |
To go through the center console, you have to pull the back seat in order to get wires under the carpet. The way that I did it was under the door sills. It was easier to do it this way, And you dont see any wires.
Mar 24, 2003 - 7:07 PM |
Enthusiast Joined Aug 29, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
yep just do it under the door sills, theres plenty of room and its easy.
Mar 26, 2003 - 8:21 AM |
Thanks, what is the easiest way to get under the sills and the easiest way to run the power wire from the battery through to the boot
Mar 26, 2003 - 4:40 PM |
to is a lot easier to work with wires and stuff if you take the front seat and back bench seat out. trust me it makes everthing a lot easier.
Apr 6, 2003 - 11:15 AM |
Enthusiast Joined Mar 17, '03 From you like to know. Currently Offline Reputation: 0 (0%) |
me i just drilled a hole up under the drivers side gas peddle sinc emine is a st no hole anywhere!!! so yeah all my wires go up through the center console under the seat is my amp so that is the best way.
Apr 6, 2003 - 12:47 PM |
Enthusiast Joined Oct 1, '02 From PA Currently Offline Reputation: 0 (0%) |
can someone take a pic of where they ran the wire through the firewall?
i cant find that hole to run the wire from the battery to the amp. edit: nevermind...i found a pic in a different thread This post has been edited by 96cel_John: Apr 6, 2003 - 12:50 PM |
Apr 6, 2003 - 8:23 PM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
Enough room for 0 gauge?? I'll be running 0 awg to my two L7s and a amp to the rear speakers. 1200 rms to subs plus the 6 3/4s.
Lo-Fi Version | Time is now: November 28th, 2024 - 1:37 PM |
