driving home today, i noticed that my headlights and foglights have no power, but the high beams work. i checked the fuses and i can hear the relay click over. i also did a visual inspection of the bulbs and they seemed ok.
so i did some more testing, it seems to be a grounding issue. i get 12v right at the red wire from the bulb harness, with the mutimeter balck touching a chasis ground poit, but if i just stick the multi meter into the harness plug i get nothing. any ideas? i guess as a last resort, i could just spice in a wire and attach it to the chasis as a ghetto rig, but id like to know why its happeneing in the 1st place. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) ![]() |
trace your wires inch by inch back, u may have possible broke connection somewhere. i have the toyota electrical dealer cat. if u need i can scan and email some other pages but there for 5sfe only, i dunno what or if any changes were made with your swap? i dont think it should interfer but
![]() let me know jon |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
It's been so long that I can't even remember...are the headlight relays easily accessible under the hood?
do any of you guys know how the ground wires run from the headlights? i have a totyota book, and read the diagram, but id like a visual or a pic .
i reading the diagrams i figured out that the headlight and fogs get ground through the same wire. i disconnected my fog lights and touched the ground wire to my fmic (yet another good use for a fmic ![]() it should have nothing to do with my 3sgte wiring, beacuse the lights for the car are part of the body harness. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Are the low beams switched on by ground or by +12volts?
I can't remember how the low beams are set up, but if I remember right, the high beams are switched by ground. At least I think...but thinking has gotten me no-where today. -------------------- New Toyota project coming soon...
no, everything is turned on through the 12v line. i extended the ground wire from my fogs and connected it to the body with a 10mm bolt. everything is back to normal. i just wish i knew how the hell this happened in the 1st place.
Lo-Fi Version | Time is now: February 23rd, 2025 - 3:18 PM |
