2 Pages V  < 1 2
> drivers side axle
post Jan 10, 2006 - 4:36 AM
QUOTE(popstar @ Jan 10, 2006 - 3:08 AM) [snapback]376664[/snapback]
Yo Guy's......
this is scary, how often have some of you changed you CV axels ???
i've got to change mine and it's gonna cost me best part of $500 just for the parts
plus maybe waiting 6 weeks (worst case) to get them from Japan frown.gif (remember i'm in Russia)
what the life expectency on the CV axel cause i'm thinking i should order the other side at the same time if they go regular ??????
it all depends on how you drive. ive seen some last as long as 100,000+ miles while others go sooner. mine went early because they kind of got tossed around during my engine swap. since i put new ones in, i didnt have any more issues.
here in america, we have a lot of companise that take in your old axels and rebuild them for about 75$ with lifetime replacement warrenty. i know that if i was to go to the local toyota dealer here, it would be around 250$ per side for brand new ones.
post Jan 10, 2006 - 1:39 PM
mikew04
Joined Feb 19, '04
From austin tx
I just replaced mine last summer and they already went out on me. Most likely because I got rebuilds by CCT before I got advice from ^ on getting rebuilds from carquest.
post Jan 10, 2006 - 5:43 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
im doin the same thing and im still stuck! so is there any unbolting to do then?
IPB Image <--- I miss :'' (
post Jan 10, 2006 - 9:30 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
never mind i got it off... wish i got it on video. FINALLY i can change out my seal. if ur changing the clutch u can take down the tranny with the cv axle on it. just take the passenger driveshaft off.
This post has been edited by My2Celi: Jan 10, 2006 - 9:34 PM
post Jan 11, 2006 - 10:17 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
bump
This post has been edited by My2Celi: Jan 12, 2006 - 2:35 AM
post Jan 12, 2006 - 8:48 PM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
I had the same problem while doing my axles, except I had trouble with the passenger side. The driver side popped right out. For the other, I tied a strong rope to the axle behind the big piece of metal just outside the differential. It took me and 2 other guys to jerk it out. This was done after prying, pulling, crying, kicking, and cursing.
Use EXTREME care when changing seals. It's tricky finding a spot to pry them out easily. I found it much easier to take a flathead and a hammer and make a little dent in it, and then prying around that dent.
This post has been edited by Delta_Phoenix: Jan 12, 2006 - 8:52 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 24th, 2024 - 9:53 AM
