> i'm not sure, struts
post Dec 22, 2004 - 9:45 AM
Shigexile
Joined Oct 30, '03
From IL
alright, i was going to install my coilovers but they wouldn't fit and they said i need struts. So i'm thinking about buying struts for about half a year and decided to buy KYB GR-2 non-adjustable (How low can these be able to hanndle?). Now these only come with the struts but is there anything else i should get along with the struts? Like do i need the boot and all? Thanks guys! (and girls).
post Dec 22, 2004 - 9:47 AM
Shigexile
Joined Oct 30, '03
From IL
the site i going to buy from is Option Imports
post Dec 22, 2004 - 9:53 AM
GR2s are OEM upgrades, and they're lifetime depends on your driving and what not. However if your coilovers dont fit its probably due to the fact that they (struts) need to be grinded down. Check out the How To Install Coilovers for more details.
Coilover How To
Oh and you may wanna get a mount just while ur doing all this.
This post has been edited by Supersprynt: Dec 22, 2004 - 9:54 AM
post Dec 22, 2004 - 9:56 AM
Shigexile
Joined Oct 30, '03
From IL
what does the mount do?
post Dec 22, 2004 - 10:01 AM
help support the strut and if yours are worn (or close to it) then you'll start to hear popping and stuff - just easier to change them out befor theres a problem.
post Dec 22, 2004 - 10:05 AM
Shigexile
Joined Oct 30, '03
From IL
i see. you said earlier that i might need to grind, but that happened when i tried to put it on with stock struts. So willl it change if i get the GR2 put in? the how-to only was talking about the installation of the coilovers so i was confused.
This post has been edited by Shigexile: Dec 22, 2004 - 10:06 AM
post Dec 22, 2004 - 10:06 AM
No with coilovers you will most likely have to grind down the strut housing - read the How To (why its there) and you'll see its not tough shouldnt take too long.
post Dec 22, 2004 - 11:55 AM
mikew04
Joined Feb 19, '04
From austin tx
You can find struts for cheaper. Try tire rack (tirerack.com,) the fronts are 40 and the rears are 47, and they are a great company to deal with.
post Dec 22, 2004 - 1:08 PM
THose are the inserts, you can get the full struts (rears) for $87 a pair and you dont have to take anything apart.
post Dec 22, 2004 - 6:27 PM
Shigexile
Joined Oct 30, '03
From IL
Nice, thanks guys. i Gonna buy them.
This post has been edited by Shigexile: Dec 22, 2004 - 6:55 PM
Lo-Fi Version Time is now: December 3rd, 2024 - 12:05 AM
