> Any one know where this goes?, Ground Wire
post Dec 22, 2004 - 2:34 PM
drdos
Joined Aug 19, '03
From Buffalo,NY
Well im finaly putting the car backtogether. and im down to the last thing of this wire.
it comes off the negative termanal from the battery, and spilits into 2. the 1 part of the wire grounds into the front of the car on the chases near bumper. the other one i have no idea. here are some pics.
yellow wire goes to this..
thats in the front of the battery near bumper.
now for the red wire i have no idea. here are some pcis
does any one hvae any idea where it mounts 2?
thanks
post Dec 22, 2004 - 2:48 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
correct me if im wrong but isnt that the tranny ground?
-DMC
post Dec 22, 2004 - 3:00 PM
creis
Joined Jan 10, '04
From Shoreline, WA
its the tranny ground, or engine block ground, my money is it being for the block the tranny is kinda already grounded though the mounts, where as the motor is sitting on rubber bushings, but I may be wrong.
post Dec 22, 2004 - 3:01 PM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
QUOTE(thedevilmaycrie @ Dec 22, 2004 - 7:48 PM)
-DMC
[right][snapback]225138[/snapback][/right]
I think your right. Im at work and can run out to the car to get a quick peek at it if noone else doesnt know off the top of their head for sure
post Dec 22, 2004 - 3:22 PM
Anub1s
Joined Nov 27, '03
That goes to the top of the tranny. A 14mm bolt holds it on I believe.
post Dec 22, 2004 - 5:02 PM
post Dec 22, 2004 - 6:52 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
-DMC
post Dec 22, 2004 - 9:17 PM
yep 14mm tranny ground...dont drive the car without it or you may start a fire! (not joking)
post Dec 23, 2004 - 6:05 AM
maikl
Joined Mar 3, '03
From cyprus
anywhere in the chassis of the car is ok!!!!
post Dec 23, 2004 - 7:05 PM
97GTinKC
From KC
QUOTE(maikl @ Dec 23, 2004 - 4:05 AM)
[right][snapback]225458[/snapback][/right]
Actually, no, the red one NEEDS to be bolted to the engine block or transmission, the yellow one is going to the chassis.
what could happen if you bolt both to the chassis is you could fry several things next time you engage the starter as you no longer have the main ground from the starter (bolted to the block) back to the battery, current will take the next lowest resistance path - if at all, usually thru the ignition module and/or switch or possibly your throttle cable or shift cable - not a pretty sight - putting 100-200 amps thru an unintended path / he was not kidding about the fire. I have seen all 3 of the above happen.
Lo-Fi Version Time is now: November 27th, 2024 - 10:06 AM
