> Bodykits w/ springs, Who has 'em?
post Dec 23, 2004 - 1:11 PM
chucho
Joined Mar 23, '03
From New Orleans
I would like to drop my car but am afraid of messing up my front apron. The roads over here are not the best, not really pot holes but up and down roads ex. surges of concrete getting hot and buckleling. I would get the eibach pro-kit or some Tein's. The Tein's would give me about an 1" in drop which wouldnt lower it to drastically. Y'all let me know y'alls experiences. EX: Regular travel, dips in roads, speed bumps, elevated driveways. Thanks
post Dec 23, 2004 - 1:26 PM
D4W5
Joined Dec 15, '04
From newcastle england
im gonna drop mine 40mm/1"3/4,might get away with 70 mm but thats too much for you,im also putting a 404 kit on which will make it another 35mm lower along with the "17,should be ok,how far does yours sit off the floor,you could try soms koni adjustables and set it hard as fcuk,just a thought
post Dec 24, 2004 - 11:47 PM
i have the vader...2.5" drop and with 14s you need to be VERY careful...with 18s i'm pretty good but steep drives you need to take it slow
post Dec 25, 2004 - 12:07 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i had the 15"s with a 404A lip and the Sportlines.
I was fine, as long as you are careful w/ ramps and such, you should be fine. The stiffered the springs the less of the amplitude of the oscillation from w/e-it-may-be...
so the chance of smacking into the ground MAY ultimately be lowered...
post Dec 26, 2004 - 9:14 PM
forkee
Joined Nov 13, '02
From So Cal
I got tein lowering springs and the invader front bumper. I can't get over speed bumps, hahaha. I dunno if u can see my sig pic that well, but I'm sitting right over a drain dip and the front end is touching the ground and I couldn't back up any further.
post Dec 26, 2004 - 9:57 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
what about s-techs, 404 front and 16 inch gts rims?
- Ryan
aim: rkgreen04
post Dec 26, 2004 - 10:25 PM
chucho
Joined Mar 23, '03
From New Orleans
thanks forkee, i really want to lower it but dont want the problems of scraping
post Dec 26, 2004 - 10:59 PM
just do it you'll be fine just use common sense and don't go 40 over a speed bump.....go at an angle and SLOW you'll be fine
see my sig VVVV thats 6" above ground wtih 14" i was 2" above ground....just use common sense and i was fine
This post has been edited by playr158: Dec 26, 2004 - 11:00 PM
post Dec 27, 2004 - 1:04 AM
The__J__Factor
Joined Oct 11, '04
From Gold Coast, Australia
your car looks hella low as it is man, i wouldnt worry about doing anything to it
post Dec 27, 2004 - 2:17 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
I got major scrapping problems on driveways. I make speedbumps, but driveways I got to take at an angle. My rear is extremely low. I got to get airbags, thats the solution.
post Dec 27, 2004 - 2:25 AM
lol airbags ride like crap......but if your smart you won't scrape....
and j factor....i looks low cause he's in grass thats another 3" so thats about 9 off the ground
post Dec 30, 2004 - 8:42 AM
D4W5
Joined Dec 15, '04
to be the man in england you need to be in maxpower mag,there are loads of **** eurotrash cars[saxo,corsa ,i have a fully modded corsa ,cant compare to a jap car] and it needs "18+,sittin 20mm from the ground at the most,check them out on www.maxpower.co.uk
Lo-Fi Version Time is now: November 28th, 2024 - 5:03 PM
