> 3sgte stroker, i finally decided on my spare 3sgte...
post Dec 23, 2004 - 2:32 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
im thinkin on making my spare 3sgte a stroker input please...
how do you build these with 5sfe... is it the 3sgte block, rods and pistons w/ a 5sfe crank shaved down?
-DMC
post Dec 23, 2004 - 2:36 PM
Junior
Joined May 5, '03
From Toronto
3s block with 5sfe crank, rods, and pistons. There are 3sgte stroker kits in the market.
post Dec 23, 2004 - 2:37 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
yeah but making one is cheaper
-DMC
post Dec 23, 2004 - 3:57 PM
Jun makes a 2.2L for 3400
post Dec 23, 2004 - 9:07 PM
1bwilson
Joined Aug 30, '02
From Maryland
Its 5sfe block, rods,crank,pistons.
3sgte head, cams, intake manifold.....
You may have to drill out the some water jackets depending on the gen 5sfe block.
Member of Team 5sfTe
post Dec 23, 2004 - 9:21 PM
shid
Joined Jan 8, '04
From LA
QUOTE(Supersprynt @ Dec 23, 2004 - 8:57 PM)
[right][snapback]225656[/snapback][/right]
Yeah, I'd say his plan is cheaper. A lot cheaper.
post Dec 24, 2004 - 11:44 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
If you do it this is the best way to go 3sgte head & pistons
5sfe block, crank & rods this is the cheapest way & all your parts are stock!
post Dec 25, 2004 - 12:30 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(Punch @ Dec 24, 2004 - 9:44 PM)
[right][snapback]226194[/snapback][/right]
Think about it. 3s pistons are so much cheaper than 5s ones. If they fit the 5s block everyone would have either upgraded to stock or forged 3sgte pistons. Im fairly sure the 3s pistons will not fit. Maybe with the 3s head it'll work but Im still very unsure.
I however know for a fact that 5s pistons and 3s rods fit with no problem. The crank jurnals have to be turned down a bit but that is all.
post Dec 25, 2004 - 1:28 PM
Junior
Joined May 5, '03
From Toronto
people, do some research. It is not easy to fit a 3s head on a 5s block. Further more, the 5s has a bigger bore and a longer stroke than the 3s. Hence to bore and stroke a 3s would require the changing of the pistons (bore) and changing of the crank and rods (stroke). You could fit stock 5s crank, rods and pistons. Spend the extra money and get better rods and pistons and use a 5s crank. Make sure to get it all balanced before install. Don't forget you'll have to get a machine shop to bore out the 3s a little.
post Dec 25, 2004 - 8:10 PM
FallenHero
Joined Dec 26, '02
From Alabama
www.club4ag.com
go to tech and then look under 7ag/5ag info
post Dec 27, 2004 - 5:21 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I think Junior hit this one on the nose. lol. The 5s is a 2.2 liter and the 3s is a 2.0 liter. Go get the stroker kit. Even if you bore out the 3s block to be a 2.2 liter, the 5s rods aren't going to hold big amounts of boost.
post Dec 27, 2004 - 7:05 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(celica3sgte @ Dec 27, 2004 - 10:21 PM)
[right][snapback]227088[/snapback][/right]
Junior and yourself actually have it the hard way. Not incorrect... but just mis-interpreted. There are versions of the 5S block that you can simply mate up the 3SG head to. Regardless of bore differences, so long as a proper head gasket is used, like an overbored 3SG gasket, it'll be fine. You can't bore out the 3SG block too much, nor can you drop in the 5S crank without some machining. I doubt the 5S crank and fit in the 3S block without some machining. From there, even with the stock 5S bottom, mild boost can be applied so long as the tuning is good. Stroking with the 5S bottom-end will be a whole lot cheaper than buying an aftermarket stroker kit for the 3SG.
post Dec 27, 2004 - 11:55 PM
Punch
Joined Jan 29, '04
user posted imageI have a stock 5s block that I took apart a some 3s pistons that came across in the shop I just got a 3sgte head , when I get some time to go down there I will try everything too make sure; but the pistons are the same size they fit the rods
This post has been edited by Punch: Dec 27, 2004 - 11:55 PM
post Dec 28, 2004 - 1:06 PM
Junior
Joined May 5, '03
From Toronto
If you look at the specs for the 5sfe and 3sgte the differences in the lower end is the bore and stroke length. The bore difference is 1 or 2 mm. The main reason the 5s has a larger displacement is due to the stroke length. From what I know, from research done in the past, the 5s crank will fit right in. Its been debated, check the MR-2 forums, whether or not a 3s head can be mated with a 5s block. It can be done, but its not worth it.
post Dec 28, 2004 - 2:58 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Junior @ Dec 28, 2004 - 6:06 PM)
[right][snapback]227370[/snapback][/right]
I really doubt the 5S crank will simply drop in. The 5S crank is pretty big compared to the 3S... but whatever. Nothing against the MR-2 guys, but they're also the guys who claimed to have used S2000 shimless buckets to do shimless conversions on 5SFE's... when in fact, the S2000 doesn't even use buckets/shims... so don't take what they say as the gospel truth...
IMO, the 3SG base is far better anyway. Unless you're doing an all out drag motor with big torque as the goal, the 3SG is a perfect squared motor with some of the toughest factory rods... and the 5S bottom-end just can't match that without a lot of custom work.
post Dec 28, 2004 - 3:11 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
geez nm to much trouble imo i think ill just give the 3s away... and no YOU cant have it...
-DMC
This post has been edited by thedevilmaycrie: Dec 28, 2004 - 3:12 PM
post Dec 28, 2004 - 3:30 PM
can i have it?
post Dec 28, 2004 - 3:32 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
sry shes already spoken for... as long as he buys a gt...
-DMC
This post has been edited by thedevilmaycrie: Dec 28, 2004 - 3:33 PM
post Dec 29, 2004 - 5:56 PM
Junior
Joined May 5, '03
From Toronto
I don't think people realize that a 2.2 stroker kit for the 3sgte has the same specs as a 5sfe pistons/crank/rods.
post Dec 29, 2004 - 10:06 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Junior @ Dec 29, 2004 - 10:56 PM)
[right][snapback]227938[/snapback][/right]
Proof is better than assumption... but until some proof is provided... I'll stick to my gut.
Lo-Fi Version Time is now: November 29th, 2024 - 9:02 AM
