Neon Strut Brace |
Neon Strut Brace |
Dec 24, 2004 - 10:02 PM |
Enthusiast Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
does anyone have close up pics of a neon strut brace mounted on there 6Gen Celi..
Dec 24, 2004 - 10:15 PM |
ta da!!!
yup there it is.. nothing much to look at |
Dec 24, 2004 - 11:43 PM |
Thats exaclly the kind of pic i was looking for. Drilling my holes now, i wanted to see if mine line up like everyone elses. One hole is reall close to the side, just like yours. Also i didnt know if the bar was to the front or the rear, i assumed the front.
Thank You, did anyone put the factory v-shape one back on? I think im gonna. |
Dec 25, 2004 - 12:15 AM |
My Celica didn't come with the factotry V one. I did pick one up and try to put them both on. They both don't fit together on the strut top. It is one or the other.
Hanyo, clean your engine -------------------- |
Dec 25, 2004 - 12:19 AM |
longer bolts
Dec 25, 2004 - 12:38 AM |
won't fit. It is impossible. No matter what. No jive
Dec 25, 2004 - 12:46 AM |
nothing is impossible if you think about it
or use thinner bolts on top This post has been edited by playr158: Dec 25, 2004 - 12:49 AM |
Dec 25, 2004 - 12:54 AM |
nope. impossible unless you modify the stock one to make it sit flat. Which means cut or grind a lot of metal. That is if you want to put the neon one on top which would be your only option because the neon bar is in the way for the actual V bar. as pictured
got a stock one ? look at it and look at Hanyo's pic. then maybe, just maybe, you might understand... if you don't have the stock one or seen it detailed enough to know what I'm talking about, then why talk... This post has been edited by Batman722: Dec 25, 2004 - 12:57 AM -------------------- |
Dec 25, 2004 - 12:56 AM |
well i don't have either lol but i can tell you eventually I WILL do it
anything can be done with enough thought |
Dec 25, 2004 - 12:58 AM |
good luck. I tried. wasn't worth the effort with the stock one. Trust me
This post has been edited by Batman722: Dec 25, 2004 - 12:59 AM -------------------- |
Dec 25, 2004 - 1:05 AM |
i'll prove you wrong...lol its really not that hard the way i see
Dec 25, 2004 - 2:12 AM |
ill let ya know tommorrow when i do it!!
Dec 25, 2004 - 5:34 AM |
QUOTE(Batman722 @ Dec 24, 2004 - 10:15 PM) My Celica didn't come with the factotry V one. I did pick one up and try to put them both on. They both don't fit together on the strut top. It is one or the other. Hanyo, clean your engine [right][snapback]226222[/snapback][/right] lol.. i will when it gets warmer.. its freezing out side. |
Dec 25, 2004 - 9:31 AM |
my drills dead. What a crap of garbage... I need a new drill, only got like 1 1/2 wholes drilled.
Dec 26, 2004 - 4:17 PM |
do you think that the factory v-bar, does anything anyway? it looks pretty weak.
Dec 26, 2004 - 6:03 PM |
Enthusiast Joined Feb 18, '03 From Hermiston, OR Currently Offline Reputation: 0 (0%) |
that Neon strut brace is from the 1st gen right?
Dec 26, 2004 - 6:25 PM |
i just got my neon one on, the clearance fit great. and wow, u do notice a big driving difference, im painting the factory one, and going to install it tommorrow.
Dec 26, 2004 - 7:16 PM |
not gonna work...
Dec 27, 2004 - 6:51 AM |
ive heard all your discussion Batman. Im gonna see if i can make it work. ill make sure i keep u updated.
Dec 28, 2004 - 5:22 PM |
sooo SAP
booo BAT |
Lo-Fi Version | Time is now: December 4th, 2024 - 6:52 AM |
