Christmas Present, Here's mine |
Dec 25, 2004 - 12:49 PM |
Enthusiast Joined Mar 9, '04 From San Carlos, CA Currently Offline Reputation: 0 (0%) |
and |
Dec 25, 2004 - 1:08 PM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
nice
Dec 25, 2004 - 1:20 PM |
ahhh, those are those gren stuff pads right?? Lemme know how they work for ya, cause i think by spring time, im goign to need some new pads..
Dec 25, 2004 - 1:41 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Someone's gonna have a nice brake setup. Get stainless steel brake lines.
Dec 25, 2004 - 4:47 PM |
Enthusiast Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
Good stuff right there.
Dec 25, 2004 - 6:26 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
EBC pads are awesome. i used green stuff on my celica and currently have the same on my MR2. they work brilliantly, though they will wear a bit faster than factory, especially with cross drilled/slotted rotors
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Dec 25, 2004 - 9:33 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
gonna look great. where did you get the brake pads from?
Dec 25, 2004 - 9:47 PM |
just a little tip, make sure you take those disks to a shop/auto store and have them turned, its always a good idea to do that because it will ensure there prefectly level so you dont have a wabbly ride, even if they say they come turned from the factory.
Dec 26, 2004 - 12:33 AM |
QUOTE(BLINKYxMUNKEY @ Dec 25, 2004 - 7:33 PM) gonna look great. where did you get the brake pads from? [right][snapback]226505[/snapback][/right] tirerack.com |
Dec 26, 2004 - 12:07 PM |
only get them from TireRack
you try to go a cheaper route and you might get screwed like i did... nice rotors -------------------- |
Dec 26, 2004 - 12:23 PM |
I have a few questions. First, Is the gt front bigger then the st? also why dont they make green-stuff rear ones? also if i were to tyr an get some green stuff pads, would it be worth it cause i still have drum rears, or should i upgrade to rear disc and then get what pads? Thanks and sorry im not trying to take over this threa just not start another one.
Dec 26, 2004 - 1:30 PM |
Enthusiast Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
If you don't mind, how much did all of that cost you?
-Josh |
Dec 26, 2004 - 2:27 PM |
QUOTE(Digndoug @ Dec 26, 2004 - 10:23 AM) I have a few questions. First, Is the gt front bigger then the st? also why dont they make green-stuff rear ones? also if i were to tyr an get some green stuff pads, would it be worth it cause i still have drum rears, or should i upgrade to rear disc and then get what pads? Thanks and sorry im not trying to take over this threa just not start another one. [right][snapback]226613[/snapback][/right] I'd assume the rear brake pads would be the same as the front, but since I still have drum rears I only got the one set. GT rotors are bigger than ST, as far as I remember. I only upgraded the front brakes because I didn't feel like messing with swapping the rear, plus it was a christmas present it would be too expensive. QUOTE(gt_driFFter @ Dec 26, 2004 - 11:30 AM) If you don't mind, how much did all of that cost you? -Josh [right][snapback]226630[/snapback][/right] I'm not sure, because my parents bought it as a christmas present, but you can check out the prices on irotors.com for the rotors, and tirerack.com for the EBC greenstuff pads. |
Lo-Fi Version | Time is now: December 4th, 2024 - 11:40 PM |
