> 4age head on ebay, Worth it with a little TLC?
post Dec 26, 2004 - 4:56 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33617
Ok there it is i have seen it up for a few weeks now but im not really sure if its worth it.
I am ready to pull out my engine and start the 7agte conversion and i thought this would be a good start.
What do you guys think about it?
post Dec 26, 2004 - 9:28 PM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
Yes this would be a good start because it`s the large port version , but think about a rebuild of the head for reliability and performance.
Even with the head you`ll need to find out a corrolla gts fwd for others parts also.
Claude
post Dec 26, 2004 - 11:45 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
You'd have to source a somplete intake manifold and throttle body with attached sensors (TVIS plate optional), fuel rail, injectors, distributor, coil/ignitor, AFM, and at least a partial engine harness with CTS plug, O2 plug, temp plugs, AFM plug, TPS plug, and ECU plugs. The harness part can be eliminated if you choose to go with a standalone ECU. For the engine harness, I highly recomend you source one from a 92 Geo Prizm GSI if at all possible. That way, you can go with a complete MAP set-up instead of the AFM. Some models of the Corolla GTS AFMs don't read-out the proper voltage for a piggyback set-up so tuning will be nearly impossible with the stock ECU, so I'd either reccomend a MAP sensored JDM set-up (or the VERY VERY rare USDM 92 Geo Prizm GSI wiring set-up) for the best tuning capabilities.
post Dec 26, 2004 - 11:48 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Whats the power increase or reason for swaping the 4age head? I know its a performance designed head compared to a economey. But I dont really see why it would be worth swaping all that, and why not just swap the whole, engine for e comparable bottom end.
post Dec 26, 2004 - 11:56 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Digndoug @ Dec 27, 2004 - 4:48 AM)
[right][snapback]226830[/snapback][/right]
The reason would be to maintain the 7A displacement and gain the 4AG flow and aftermarket support. A stock 4AG head can probably out-performan a street-port 7AF head anyday...
post Dec 27, 2004 - 12:03 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(Kwanza26 @ Dec 27, 2004 - 4:56 AM)
[right][snapback]226835[/snapback][/right]
Yeah I also forgot that the 4age was a 1.6 .... i wounder how much power it would run n/a
post Dec 29, 2004 - 1:14 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
Aye, i completely understand thats it's not all ill need was just wondering if it would be a good start and you more then answered my questions.
As for the ECU i have a motec dealer a few miles from house, So I will more then likely bring it up to them when i am done and see what the Motec M4 Standalone will run.
post Dec 30, 2004 - 2:52 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Skate4mindgame @ Dec 29, 2004 - 11:14 AM)
[right][snapback]227777[/snapback][/right]
A: you are going to spend a grand or so on a standalone EMS... on an engine that won't buck over 130 whp... meaning you are Hella dedicated to the 7afe.
Or....
B:you don't realize that your money can be better spent on a swap of some sort than on a econo-block boat anchor.
Lo-Fi Version Time is now: February 20th, 2025 - 1:52 AM
