2 Pages V  < 1 2
> Interior Paint
post Jan 1, 2005 - 3:57 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
I just modded it, and put some 3mm LEDs in it....so i figured i might as well paint it.......i used kyrlon fusion and its amazing......if anyone is going to paint plastic definatly see if they have they color you want, it didnt need to be sanded or primed because its specialy made for plastic.....
post Jan 1, 2005 - 5:16 PM
SinisterWhisper
Joined Nov 14, '04
wow that makes me want to do mine now but sadly its raining today and I work tomorrow frown.gif. Quick question I want to make all my stuff look smooth and glossy so should I sand it and then after I paint use a a few clear coats?
post Jan 1, 2005 - 9:22 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
yea thats what i did....make sure you uses liek 220 or higher grit sandpaper and spray in a light coats.....then when your ready for clear coat just do a few light coats and it should look pretty sweet!
post Jan 1, 2005 - 9:29 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
i got my interior paint white and i wanna change it to a diff color...can anybody can tell me how i can remove the old paint on the interior ...that would be alot help full...please sombody help
As the time goes by
My life change...
I hope i wont change
Nor my heart
but it is broken..wat can i do..
IT life...I hate it...but i lov my creation
post Jan 1, 2005 - 9:33 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
try sanding or maybe a paint thinner? i think if you sand it you should be able to paint right over it
This post has been edited by Theyellowdart084: Jan 1, 2005 - 9:33 PM
post Jan 1, 2005 - 9:36 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
any kind of sandpaper??thanks for the answer
As the time goes by
My life change...
Nor my heart
post Jan 1, 2005 - 9:44 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
the regular 3m should be fine....i just bought some more at wallmart for like 3 bucks......just make sure you get the right kind of grit size (lower grits are good if you are trying to completely wipe off paint and higher grits are good for finishing touches)
post Jan 2, 2005 - 12:35 AM
YO you missed vents dude
the 2 or three on the top of the dash,
the one closest to the windshield.
the one above the driver side left vent..
and possibly the one above the passengerside botom vent if there is one there
post Jan 2, 2005 - 12:39 AM
shid
Joined Jan 8, '04
From LA
QUOTE(playr158 @ Jan 2, 2005 - 5:35 AM)
[right][snapback]228958[/snapback][/right]
I'd miss those on purpose. It looks weird..
post Jan 2, 2005 - 6:21 AM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
yea im still debating on those......i think im going to definalty do the passenger vent and the other driver vent.....i just need to find some more paint the same shade
post Jan 2, 2005 - 3:15 PM
D4W5
Joined Dec 15, '04
From newcastle england
just do it dude,its diff to standard interia aint it,just do it and if it look poo,take it off,just lets see it first,cheeky!
post Jan 2, 2005 - 3:48 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
i try sandin down my parts today..and im not gettin anyway with it..still stuck on the same freak part..been lik 30 mins now..and i aint the type of guy who want do sit there and sand sand..is there anyway i can hmmm paint over my old interiour paint..on the parts...if sooo..can sombody telll me wat to do..is it the same method..lik acohol and paint then sand it down soo it look clean....then loght clear coat soo it be shoney...any help rite now will do...thanks in advance
As the time goes by
My life change...
Nor my heart
post Jan 2, 2005 - 5:50 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
There's no reason to sand all the paint off the pieces. You just need to scuff up your parts with sandpaper and repaint over the existing paint and yes, then it's the same process as before. You should have all the pieces sanded in less than 30 minutes.
post Jan 2, 2005 - 6:01 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
this is true....and if you are painting plastic there is a special paint called krylon fusion, its amasing no sanding or priming but there color selection is limitied......i used it on my xbox without priming or sanding......also try to find special adhesive sprys (ex: bulldog) they have them in the wall mart auto section and it helped me when i tryed to get the paint on the plastic......just a thought
post Jan 2, 2005 - 7:44 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
ok..let me continue sandin and by tommrrow i can be painting.thanks for the help guys and TI [ helpin me on aim]..
As the time goes by
My life change...
Nor my heart
post Jan 3, 2005 - 9:19 AM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
biggrin.gif No problem dude.....noobies need to help other noobies!!
let us know how everything goes for you....i will post a final pic of mine, im doing some light sanding to make sure everything is perfectly even and there is still that one little vent i need to do....
plus your from the best state there is....NJ represent!
This post has been edited by Theyellowdart084: Jan 3, 2005 - 9:20 AM
post Jan 3, 2005 - 9:25 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
alrite i will post picture when im done
This post has been edited by XxAxnCelica95xX: Jan 23, 2005 - 6:28 PM
As the time goes by
My life change...
Nor my heart
post Jan 23, 2005 - 6:30 PM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
it was snowin today sooo i decided to take some picture..the interior was white b4 but now it is red...i just put in a new shift knob ..the stock one look kinda plain to me soo i put in a diff one ...
Interior
Front View In Snow
As the time goes by
My life change...
Nor my heart
post Jan 23, 2005 - 7:31 PM
the thing that worries me about painting mine, is that most of the interriors ive seen end up having that "painted" look to them. i think i may take my pieces off and take them to a pro or go with a dash kit.
post Jan 26, 2005 - 8:36 AM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
see, if you dont wanna paint then definatly use a pro shop.....i think dash kits are ugly....my friend has one for his toyota and it just looks wierd.....its pretty much just a thick sticker
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 17th, 2025 - 7:56 PM
