> Turbo Q's
post Dec 27, 2004 - 10:37 PM
d3monc3lica
Joined Aug 19, '04
From Maine
Ok so I'm buying a basic turbo setup from another person on here and I was wondering, due to the fact that with this purchase im only recieving a Turbo with internal wastegate, Manifold, MAP box, oil lines, FMU, BOV, and downpipe I know that I can't just bolt this thing on and get it to work (Note, there is not intercooler but does come with piping to the intake manifold), my plans as of now are to:
Buy a SAFC, OBX Fuel Rail, Venom Injectors and possibly fuel-pump.
Now because the 6gc has a higher compression pistions and I know its bad to run boost on high compression, shoild i 100% swap the pistons out with lower compression ones or is there a way to run LOW boost with all the fuel management there. I plan on buying the intercooler and turbo timer and boost controller too but after the fuel management, but i need input, this is my first boosted car and no i dont mean stolen tongue.gif lol. Thanks
post Dec 27, 2004 - 10:56 PM
d3monc3lica
Joined Aug 19, '04
From Maine
post Dec 27, 2004 - 11:10 PM
Fox-N-It2
Joined Jul 24, '04
From Va
Skip the Venom injectors and get some RC Engineering 550cc injectors.
9.5:1 isnt necessarily high for compression. You'd be safer to run an intercooler though. If you wanted non intercooled 5psi you should be ok. Any more boost that that i'd recommend a intercooler.
On that note has anyone here tried stacking Headgaskets? On VW's we can get away with up to 3 HG's stacked to lower compression and they hold to almost 20 psi!
creis
Joined Jan 10, '04
From Shoreline, WA
well, I dont know much about the st motor but I would say you seem to have a good grasp at your your gana do. depending on how much boost you wana run the stock internals should do just fine (for low boost like 5-8 psi) I would not push it much more. (that would probibly give you like 160-170hp I think) If your upgrading your injectors (almost needed for the turbo) and fuel rail etc your probibly much better off doing the piston swap because you'll get more out for the other things and you can push it more.
post Dec 27, 2004 - 11:14 PM
d3monc3lica
Joined Aug 19, '04
From Maine
ok i just wanted to know if what i was planning would be legit, and thanks for the tip on the injectors Fox-n-it2, and yes i plan on intercooling eventually, I was just curious as to what would be a good plan to spare my car from utter destruction. And if someone has any info on the stacking headgasket thing let me know. I will only run 5-7psi at the max, now what guages are a MUST to install?
post Dec 27, 2004 - 11:35 PM
d3monc3lica
Joined Aug 19, '04
From Maine
Also , is a 2.25-2.5" exhaust the way to go or should i seek larger, say 3", I would think 3" would be a little much but hell, im no expert.....does anyone like greddy or someone make a 2.5" exhaust/ hi flow cat that I could get modified for my turbo app.
post Dec 28, 2004 - 12:46 AM
creis
Joined Jan 10, '04
From Shoreline, WA
technicly the bigger then better (if turbo'ed) but if your pushing under 10 (ish) psi it probilby wont make much diff, I would say 2.5 would be best.
Sounds like a very bad idea to me, thats not what there for, and would make it weaker. (not in hp but in its ability to hold)
well no guage is a MUST but your probilby be able to avoid "utter distruction" with a boost (to make sure your not pushing to much) oil temp (see if you turbo is cooking your motor) and oil presure (if you leaking oil, or have to much in) all of witch can help you catch something befor it happens. (you gata remember that adding a turbo not only make the motor have a bigger demand for better oil, because of the added hp, but that the turbo itself takes oil from the pan to it, meaning you'll probilby need more then normal and better then normal oil for the best performance.
This post has been edited by creis: Dec 28, 2004 - 12:51 AM
post Dec 28, 2004 - 1:18 AM
d3monc3lica
Joined Aug 19, '04
From Maine
post Dec 28, 2004 - 1:55 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
first of all, there is no Low compression pistons for 7A. Only custom made ones. There was rummors that 4AGZE pistons will lower your compression.. - they will not, actually they will rise your CR from 9.5 till 10.8... The way to lower your compression on stock engine would be using some metal head gasket in 1 mm thickness (check for 4AGE head gasket, cuz the blocks of 4A nad 7A practicly the same).
Instead of S-AFC, i recomend Emanage, cuz of its ability to control Ignition, and to control injectors. Price may be a little higher, but the wiring for injectors and ignition you can make by your self (PM me on this if you like more info)
And dont go without intercooler, you will be at high risk, cuz of bigger chance of knocking, and melting you pistons.... PM nik, he has his IC with piping for sale..
<<<<<< DCw / JDMart >>>>>>>
post Dec 28, 2004 - 10:49 AM
nik
Joined Sep 30, '02
biggrin.gif So someone want to turbo the 7afe cool i agree with doggy run a intercooler and make sure your fuel system has been beef up alittle.I did find one site that sells the 7afe piston in low comp 8.5:1 i posted the site a few times on here http://www.importperformanceparts.net/imports/pek-geo.html.
Metal is good or a copper head gasket only one or two places make them for 7afe or you can get one custom made.Or just try and find a 4age which will probably be easier.
i would go greddy e-manager better tuning capability as for the intercooler piping i have one guy on here that wants it but if he falls through its all yours if you want to buy the set up. Doggy is getting Carbon Fiber piping that he is making himself that will be hott when its done.
This post has been edited by nik: Dec 28, 2004 - 10:51 AM
post Dec 28, 2004 - 11:07 AM
d3monc3lica
Joined Aug 19, '04
From Maine
Well i plan on running an intercooler but i need to find one and somehow get it piped in, how much are lookin for nik?and also how much are u making the CF ones for doggy?? as for the e-manage how hard is it to setup andht doesnt the harness come with the damn thing GRRRRR, lol i just want to know what id need to set this all up safely without killing my cash flow.
This post has been edited by d3monc3lica: Dec 28, 2004 - 11:11 AM
post Dec 28, 2004 - 11:22 AM
forkee
Joined Nov 13, '02
From So Cal
well pretty everyone already covered it. also don't skimp on the fuel pump. 97sccelica is gonna come here and show you pics of his piston. expect to pay a pretty penny to get everything running smoothly.
post Dec 28, 2004 - 11:30 AM
nik
Joined Sep 30, '02
QUOTE(d3monc3lica @ Dec 28, 2004 - 9:07 AM)
[right][snapback]227336[/snapback][/right]
I think doggy is just making a set for himself (not sure) I'm selling mine for $320 shipped the e-manager comes with a harness that you or someone need to splice into you ecu you can get a diagram from toyota. on the fuel side get a pump alot of us go with the supra 255 lph and fmu for safty then run 5 psi for a month or so and see how the cars acts
side note how many miles on the car have you gotten a comp test or a leak down
and you need to change to syntech oil
post Dec 28, 2004 - 11:32 AM
nik
Joined Sep 30, '02
i think its only Forkee and I running 7afte on here maybe one other person and both of us bought our set ups from other memebers
This post has been edited by nik: Dec 28, 2004 - 12:15 PM
post Dec 28, 2004 - 12:04 PM
d3monc3lica
Joined Aug 19, '04
From Maine
well hopefully soon I will too, hahaha, my engine has a craplod of miles, 140,000 it still runs wicked strong tho, but like u said im going to put it thru the compression check and leak down test before i do anything major.
post Dec 28, 2004 - 1:20 PM
doGGy
Joined Oct 28, '02
post Dec 28, 2004 - 1:43 PM
nik
Joined Sep 30, '02
biggrin.gif doggy if you were to sell any of your CF creations everyone on here would be lining up to buy one me included tongue.gif i think that will be my next big project learning to lay CF i can lay fiberglass hopefully its not too much harder.
post Dec 28, 2004 - 6:53 PM
d3monc3lica
Joined Aug 19, '04
From Maine
its the same basic process
post Dec 29, 2004 - 1:15 AM
doGGy
Joined Oct 28, '02
no.
cuz if you want to make it all clear and good, you have to use different epoxyd, and with CF you CANT make any mistake cuz all mistakes will be visible.
QUOTE(d3monc3lica @ Dec 28, 2004 - 4:53 PM)
[right][snapback]227495[/snapback][/right]
post Dec 29, 2004 - 1:37 AM
d3monc3lica
Joined Aug 19, '04
From Maine
i just use Elmer's Glue and bubble rap..............and wha~lah! Carbon Fiber, .......Muah! Tres Magnifique........ j/k yeah i hear ya Doggy i didn'y mean it was exactly the same but it is very similar its just more tedious.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:07 PM
