> Intermittent grind noise - front right wheel
post Dec 29, 2004 - 11:11 AM
erics1one
Joined Aug 27, '04
From Orange County, CA
This post has been edited by erics1one: Mar 13, 2009 - 9:49 PM
post Dec 29, 2004 - 11:45 AM
happens to me it sucks, but i think its an axel issue not a brake i think CV
post Dec 29, 2004 - 12:59 PM
erics1one
Joined Aug 27, '04
QUOTE(playr158 @ Dec 29, 2004 - 9:45 AM)
[right][snapback]227736[/snapback][/right]
How long have you had this problem?
Aren't CVs pretty cheap, but just extensive labor?
post Dec 29, 2004 - 1:14 PM
st_celica_killer
Joined Sep 23, '04
From fresno
same goes here trying to find out what is it too might be the axles or cv boots
post Dec 29, 2004 - 2:18 PM
Anub1s
Joined Nov 27, '03
Your CV Joints could be completely out of grease and grinding or your backing plate for your brakes could be gringing against your rotor something along those lines is what I think. The CV Axles are not that hard to replace but they get stuck so it might take a little convincing with mister BFH wink.gif
post Dec 29, 2004 - 2:25 PM
erics1one
Joined Aug 27, '04
Yeah I did notice a little leakage inside by the joint. Would that require replacing the unit? Or grease her up and shes ready to go?
Don't think its brake related. I lubed up all the appropriate parts last time I swapped the pads, so it should be all good.
post Dec 29, 2004 - 2:31 PM
Anub1s
Joined Nov 27, '03
The grease keeps all of the ball bearings in there from grinding together and causing bad things to happen. You should replace the whole unit, but if you want to be brave you could rebuild it and repack the joints with grease but its much easier to just buy a new one, plus it will probably last longer if you just shell out the money to buy new ones.
post Dec 29, 2004 - 3:40 PM
don't rebuild tahts a bizzle nitch....since i work at advanced auto i'm goin to just buy a new axel and see if that works
oh yea and its been goin since oh say end of july
post Dec 31, 2004 - 1:32 PM
chucho
Joined Mar 23, '03
From New Orleans
when mine was making the noise it was only when turning the wheel and only one direction. It was a bad CV joint. Which I believe I got the CV shaft w/ trading the core for 40 something and me and my dad changed it out. Not to bad to do.
post Jan 2, 2005 - 1:42 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
What exactly happens when cv joints go out? my friend's car makes that "grinding" clacking noise when she makes sharp right turns, and I know its her CV's but I dont know what happens exactly when they do that?
post Jan 2, 2005 - 11:17 PM
is bearings so whenit loses grease the metal bearings grind with more friction
post Jan 3, 2005 - 9:33 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Probably CV Joints....could be wheel bearings though also. Check your CV boots on the half shafts and see if they are busted open.
post Jan 5, 2005 - 6:13 PM
erics1one
Joined Aug 27, '04
Its the wheel bearings, getting fix atm.
post Jan 11, 2005 - 2:54 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
i got my cv boots and joints replaced, but it makes the same sound..its the grinding from the top hat of the coilover to ur stock top hat...u would need to get a kit from www.evilspeed.com
HOPE taht helps
post Jan 11, 2005 - 3:04 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The most simple and probable cause... brake pads and/or rotors...
post Jan 11, 2005 - 9:00 AM
erics1one
Joined Aug 27, '04
Well since I got the bearings fixed, it doesn't make any sound when driving. It does let out a little cry when I pull out of my parking spot, but nothing major, just a little creaking.
...and its definitly not the brake system.
Lo-Fi Version Time is now: November 25th, 2024 - 2:27 AM
