> any Major Problems with Celica's
post Mar 25, 2003 - 1:31 PM
95BlueGT
Joined Aug 30, '02
From Austin Texas
Does ne one here have gotten any major work done due to just wear on the engine and how many miles didu ahve on the car.
Personally i haven't changed a damn thing but the oil, plugs, wire, air filter and battery on my car since i got it 'bout 3 years ago.
post Mar 25, 2003 - 4:05 PM
boibleu22
Joined Sep 9, '02
From houston
a common problem with toyotas is the CV axles or shafts or whatnot tend to wear
-alex
post Mar 25, 2003 - 11:58 PM
FallenHero
Joined Dec 26, '02
From Alabama
I believe I was told a celica will last 200k with no major problems if not raced. Then about 160 if raced often.
post Mar 26, 2003 - 12:02 AM
boosted_K2
Joined Aug 30, '02
From Michigan
If you have an MT the transmission tends to be a bit tempramental, i had to have mine redone at 70K but i think thats just b/c the previous owner didnt know how to drive one...
No but I don't buy it
Cause I'm...
post Apr 2, 2003 - 12:39 AM
4bangn
Joined Apr 2, '03
From Denton, TX
Has anyone else had problems with there tranny or motor.
post Apr 2, 2003 - 12:45 AM
aaronc222
Joined Sep 22, '02
From Detroit
184k on a 95 ST, gears are worn(grind too easily), engine is in awesome shape, body needs paint, and seats need to be replaced.
I've had this car for 4 years, and have spent maybe 3k on it(including 4 sets of good tires and a clutch).
post Apr 2, 2003 - 12:50 AM
hioctane
Joined Nov 26, '02
two words:
hell no =)
post Apr 2, 2003 - 1:05 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
post Apr 2, 2003 - 1:11 AM
macavely
Joined Nov 4, '02
only major problem i had if you can call it that was my wheel bearings
post Apr 2, 2003 - 9:07 AM
bLODIA
Joined Apr 2, '03
From Sunnymead, CA
I have a major problem with mine!........Basically my valves are messed up....it sounds like a diesel....and its louder than my exhaust! Its not toyota's fault but my own.......I over raced it with out checking the oil and...well you can hear me comin from a mile away......yes its that loud! Anyone know how much to replace or fix the valves (maybe change the whole valve assembly)?!? Í can't drive it without fear of blowing up the engine!
post Apr 2, 2003 - 9:49 PM
slowceli
Joined Oct 31, '02
From grants pass oregon
replaced the wheel bearings 2 times
replaced the engine 2 times
broke a drive axle
but i love the car so i just keep fixing it
this was all in 3 years
post Apr 2, 2003 - 10:07 PM
boosted_K2
Joined Aug 30, '02
From Michigan
i also have valve problems too!
Cause I'm...
post Apr 2, 2003 - 11:11 PM
aaronc222
Joined Sep 22, '02
From Detroit
QUOTE (bLODIA @ Apr 2, 2003 - 6:21 AM)
Not sure how much it will cost on the Celica, but I did the same thing with an 88 Hyundai Excel(first car). It cost me about $1200 to get it rolling again. That was for new rocker arms and a couple of valves.
post Apr 2, 2003 - 11:44 PM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
Whoa, bummer.
post Apr 3, 2003 - 12:24 AM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (aaronc222 @ Apr 2, 2003 - 10:25 PM)
THANK YOU GOD!!!!!!! im still under warranty biggrin.gif biggrin.gif biggrin.gif
Cause I'm...
Lo-Fi Version Time is now: November 28th, 2024 - 3:45 PM
