![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) ![]() |
I have enkei wheels, but the problem is that the damn lugnuts are the key/ slotted kind. I have to problems that I need help with
1) Where can I get the socket that will fot over them 2) where can I get lug nuts that will fit that aren't these damn key/slotted ones?? Jeremy |
![]() Enthusiast ![]() ![]() Joined Aug 26, '04 From Vancouver, WA Currently Offline Reputation: 0 (0%) ![]() |
I got mine at leschwab
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
They are called tuner lugs. It's pretty common aftermarket wheels use them. I don't know if you have a Les Schwab in Ohio, but many local tire/wheel places should have them on hand.
-------------------- "It's ok to be naked girl... I'm an artist!"
But, will they have regular lugnuts so I don't have the tuners anymore. I don't like them and I think they are crap.
yeah no leschwabs here in Cincinnati This post has been edited by Jeremy1210: Jan 2, 2005 - 2:59 AM |
the ones that i got with my enkies are "gorilla lugs" ..got them from www.tires.com with the rims. you may wanna give them a call
i have goriila lugs but the tuner style as well your local shop
or ADVANCED AUTO should have regular style but doubt they will fit |
You have to use some sort of tuner lug. Most aftermarket wheels that are universal design, only use tuner lugs... so you'll have to get some. Regular lug nuts do not work. If you're having problems removing them and do not have a key... best whats to remove them would be to weld on a bolt and impact them out. Unless you can get a key... you're pretty much stuck to that.
Lo-Fi Version | Time is now: February 26th, 2025 - 3:57 PM |
