Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) ![]() |
Well guys, I got to P.R. the 28th...bought new headgasket, spark plugs, spark plug wires, spark plug grommets, rod bearings, pistons and rings the next day. The headgasket, pistons and rod bearings were replacements as Toyo House had them in stock. Originals would take a week and I couldn't afford all that time...I'm here for 2 weeks. Anyway, I couldn't find a local machine shop the 30th to put the pistons on the rods as everybody was on vacation. The 31st (yesterday) I woke up early, got the phone book and started calling all the machine shops far away from here. I found one like 30 miles away that was open so I drove there and the guy did them for me like in 5 minutes. He was a really good guy and had 4 7A-FEs in there ready to go also...I wish I would've known, hehe. Anyway, I bought oil filter and oil and went back to my buddy's house. We started working after noon and got done at 11:50: 10 minutes before the new year, LOL...we could've finished way earlier but we bull****ed a lot. Anywho, the car started rough with the MX-6 Turbo injectors and we couldn't figure out why until I remembered that the fuel regulator was set really high so I closed it to the minimum level and set the S-AFC to negative numbers on the graph. I managed to smooth out all the RPM points and now the engine runs great...very quiet and beautifully sounding...my buddy did a great job with the rebuild. By the way, I was impressed on how strong and solid the stock rods are but how crappy the pistons are...the #3 had a missing chunk from under the ring. All the other ones were great. Anyway, the exhaust still sounds horrible so Monday I'll go buy a quieter one. Also, it still smokes like crazy, so I know I need a restrictor for the oil feed line. The turbo had oil in the exhaust housing. I found out that an Autometer nitrous/fuel restrictor PN 3277 drilled to 1/16" will cure the problem of the oil passing the oil seals. I'll keep you guys posted.
PS: I can just touch the gas pedal and the car wants to take off like crazy, hehe. ![]() -------------------- |
![]() Enthusiast ![]() ![]() Joined Aug 19, '04 From Maine Currently Offline Reputation: 0 (0%) ![]() |
sounds cool SAFC is deff. something to have!!
soooohot
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
Cool, don't forget to let us know how that tuning device works out
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
QUOTE(OOBE @ Jan 1, 2005 - 9:36 PM) I found out that an Autometer nitrous/fuel restrictor PN 3277 drilled to 1/16" will cure the problem of the oil passing the oil seals. I'll keep you guys posted. [right][snapback]228943[/snapback][/right] i'm really interested in this can you tell me anymore and whats the cc on the mx-6 turbo injectors -------------------- yea your 3sgte is cool but ill stick to my 7agte
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
sounds great man. Just try not to blow it again.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) ![]() |
The CC of MX6/probe turbo injectors is 310 or 330 can remember corectly... but then i did some caunting, they are good till about 200 hp.. they must be at almost 100% duty circle at these hp numbers...
QUOTE(nik @ Jan 3, 2005 - 12:51 PM) QUOTE(OOBE @ Jan 1, 2005 - 9:36 PM) I found out that an Autometer nitrous/fuel restrictor PN 3277 drilled to 1/16" will cure the problem of the oil passing the oil seals. I'll keep you guys posted. [right][snapback]228943[/snapback][/right] i'm really interested in this can you tell me anymore and whats the cc on the mx-6 turbo injectors [right][snapback]229470[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
OK guys, my friend down in P.R. picked up the car today and said it is not smoking anymore, so the restrictor is not necessary. My dad drove the car a few times and said it was misfiring and I told him my S-AFC dropped and maybe the inside connector. So my buddy picked up the car and opened the S-AFC and yes, the inside harness was halfway unplugged. So he plugged it and the car started fine. It is boosting 5-7 PSI. Last time with the broken #3 piston, I timed from 0-70 MPH at a little less than 6 seconds...that was from a dead stop...no brake boosting. He test drove it today and said: "Dude, it was spinning those 17"s like crazy and the torque steer was getting on my nerves".
ahhh i can't wait to be boosting
It is so fun, man...but you will have to be patient and do everything right. That is why I broke the engine...because I was in a time crunch...only 2 weeks in P.R. so I turbocharged the car in 4 hours...I did everything right but a lot of details after the install were forgotten. You will not have any problems with yours as long as you do a search here in the forums for 7a-fte or 7afte...all of us with broken 7A-FTEs wrote quite a few threads about DOs and DON'Ts. You follow those to the letter, and you will not make the mistakes we all did. Pretty much all of us have spent over $5,000 in this little game because of stupid mistakes. Believe me, everything you need to know about it is here in the forums buried somewhere. You'll save time, money, blood and tears if you do a search, hehe.
awesome to hear, cant wait to see some results!
![]() -------------------- yea your 3sgte is cool but ill stick to my 7agte
Thanks, hehe. Hey, guys, which connectors in the diagnostics box need to be jumped to have the timing lowered? I lowered it 5 when I was there and the turbo spooled faster but the car didn't go nowhere. I told my buddy to lower it only 2 degress but I forgot which connectors to jumper so he can lower the timing. Let me know ASAP, eh? =o)
TE1 & E1
![]() -------------------- Former Team 5SFTE pro member ;)
I knew that but wasn't sure, hehe. Thanks for the confirmation! I'll call my buddy in P.R. right now so he can retard the timing...2 degrees!=o)
My buddy ran it today and told me the car feels sluggish when the wastegate opens. He tried to boost 8 PSI and had to dial the boost controller (Blitz Dual SBC Spec S) to 50% in order to achieve that. He says the boost is dropping from 8 to 5-6. The car pulls hard but it is not holding the boost and it is sluggish when the wastegate opens. Any idea of what this is? He hasn't messed with the timing yet. At least he smoked a few NA cars, hehe. He told me he boosted 5 and an Integra GS-R kept with him. Then he managed to get it to 8 and left the Integra behind, haha. Not bad for an auto! =oP
Lo-Fi Version | Time is now: February 25th, 2025 - 10:10 AM |
