> Subs sound not so good, They sound decent but not like i want.
post Jan 2, 2005 - 12:56 AM
urbandork
Joined Jul 16, '04
From Los Angeles
I put 10" subs in to the side pannel with a fiber glass box.
There is enought of air space and the box is sealed.
However the subs dont sound so good. Basically the sub, not the box, rattels a lot. It sounds as if a peice of paper is moving around. When i put my hand on the face of the sub it muffles it and as of now i have poly fill like stuff making it so the sub wont rattle.
I dont think the subs are being over or under powered. they are two 125 rms and 250 peak running on a 350 rms 700w peak amp set up parrell. (neg(sub) to neg(sub) to neg(amp) and pos to pos to pos)
i figured that inorder to get how much power the amp needs to be i should be adding the the two subs thus 125+125=250 which is close to the 300 rms of the amp.
Or is it that because the subs are set up in parallel that the amp should only put out around 125 rms (matching the power handlage of only one sub?)
Is the problem that im running to much power to the sub?
or is it something else. perhaps i need more layers of fiber glass?
MUCH MUCH thanks in advanced
This post has been edited by urbandork: Jan 2, 2005 - 12:56 AM
post Jan 2, 2005 - 1:12 AM
shid
Joined Jan 8, '04
From LA
Did you buy the subs used?
post Jan 2, 2005 - 1:24 AM
urbandork
Joined Jul 16, '04
From Los Angeles
nope one sub from ebay and aonther one from downtown la. Both came in box with everthing as it would new. plastic bag with tape over and all the trimmings.
Have i over powered them?
Digndoug
Joined Aug 20, '03
From Annapolis, Md
it could be to thin fiber glass and its flexing or u have air holes in it, I would sya pull it out and cheak.. but u kinda already screwed that up, but my guess is air is leaking. also it would be a ripped voil-coil. I would have to hear it to tell, but pull it out and look at the coils.. also push it lightly back and forth to see if its suctioned tight and not leakign air.
post Jan 2, 2005 - 1:37 AM
Scarrell
Joined Nov 8, '04
From Carmi, Illinois
well from what you said it sounds like the VC is f$cked.. id have to hear it to tell you... if the sub was wired wrong it wouldnt work.. if the subs are 125rms subs and you are sending them 150rms you should be fine... check your gains.... another thing is air leaking... as Dig said, push on the woofer(not too hard) and if it takes a couple seconds for it to come back up then it is sealed... if it comes right back up then it isnt sealed... try putting another woofer in there..... update us and let us know what you have come up with.....this is another reason why i dont use fiberglass.
i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U.
TrickedOutS2000: it was a vibrator my dad bought
scarr3ll: WHAT THE ****?!?11
TrickedOutS2000: yeh
TrickedOutS2000: for my mom im guessing
TrickedOutS2000: but yeah
TrickedOutS2000: eww
TrickedOutS2000: so
TrickedOutS2000: ****ing
TrickedOutS2000: wrong
My Cardomain Page.
Car Audio Central
msn: jared_s_c@hotmail.com
aim: Scarr3ll
post Jan 2, 2005 - 1:47 AM
urbandork
Joined Jul 16, '04
From Los Angeles
What would it look like if the coil riped. I looked and nothing looks riped.
Also when i have the sub out of the encloser it doesnt sound bad just like a sub out of an incloser would sound like.
also im sending 300rms to two 125rms subs (the subs are wired in parallel and not in series (you guys do know what im talking abou right?))
post Jan 2, 2005 - 1:52 AM
creis
Joined Jan 10, '04
From Shoreline, WA
broken cone, or rubber surround?
post Jan 2, 2005 - 2:35 AM
urbandork
Joined Jul 16, '04
From Los Angeles
nope nothing ripped or borken from what i can tell.
by cone you mean the face of the sub right.
post Jan 2, 2005 - 3:40 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
A do u have a norm wooden made box. if so bolt up in there and listen, I would say sence nothing looks riped and as u say it sounds out side of the box, you have air leakign from ur home-built box.
post Jan 2, 2005 - 3:45 PM
Anub1s
Joined Nov 27, '03
The coil is the copper looking stuff under the face of the sub its on top of the magnet basically. If you make the sub flex you can see if there is a tear there or not.
post Jan 3, 2005 - 1:42 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(Anub1s @ Jan 2, 2005 - 8:45 PM)
[right][snapback]229097[/snapback][/right]
will try that as well as purtting it in another box and seeing how it sounds.
will update as putting in springs and other things currently have priority.
This post has been edited by urbandork: Jan 3, 2005 - 1:42 AM
post Jan 3, 2005 - 2:53 AM
creis
Joined Jan 10, '04
From Shoreline, WA
hmm, if your sure there is no leak then its the sub, has to be something, or the amp is not putting out much.
post Jan 3, 2005 - 3:20 AM
urbandork
Joined Jul 16, '04
From Los Angeles
so its for sure not me over amping my subs right?
post Jan 3, 2005 - 4:16 AM
Anub1s
Joined Nov 27, '03
Its not exactly easy to screw up a sub install in the wiring department. If you can read + and - symbols you should be okay.
post Jan 3, 2005 - 1:49 PM
urbandork
Joined Jul 16, '04
From Los Angeles
yeah i know i got all the wiring down hoever my subs have an rms of 125 each and my amp puts out 300 rms. I have the subs hooked up on parallel meaning that all the negs are hooked up adn all the pos are hooked up together. (in stead of being in seres neg to pos)
i figured that i need to combine the rms of the subs to get what rms of the amp i should have. Thus 2x125=250 which is close to 300. However i could be rong and perhaps i shouldhave only had an amp that put out around 125 rms, that of one sub.
post Jan 3, 2005 - 2:57 PM
Scarrell
Joined Nov 8, '04
what are your gains at?
TrickedOutS2000: so
My Cardomain Page.
Car Audio Central
aim: Scarr3ll
post Jan 3, 2005 - 11:52 PM
urbandork
Joined Jul 16, '04
From Los Angeles
little less then half
post Jan 3, 2005 - 11:56 PM
dabbill
Joined Aug 26, '04
From Vancouver, WA
leaks in the box wouldnt cause what he is describing. To me it sounds like your voicecoil is blown, or if you have 2 subs 1 is wired 180 out. You could try to reverse the wires on 1 of the subs.
Pali_playa
Joined Apr 4, '04
From VA, USA
only thing to do is trouble shoot, try those subs in a normal box, then try diff subs in the fiberglass box, etc. only way to find out whts wrong
post Jan 4, 2005 - 1:21 AM
Scarrell
Joined Nov 8, '04
what kind of subs and amp are you using
TrickedOutS2000: so
My Cardomain Page.
Car Audio Central
aim: Scarr3ll
Lo-Fi Version Time is now: December 4th, 2024 - 10:06 AM
