> BIG BRAKE KIT, BIG BRAKE KITS
post Jan 2, 2005 - 3:35 PM
nightrider
Joined Apr 26, '04
From London
Hi, does anyone have a bib brake conversion for the st202? if so where and what company?
More Power to your BOOM BASS
post Jan 2, 2005 - 3:53 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
I'm fairly sure not. But you can use any kit for a 7th gen, as they are suppose to bolt up. This has been researched on this forum and all research shows it should work, but no one has tired it yet.
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jan 2, 2005 - 4:41 PM
shid
Joined Jan 8, '04
From LA
The 7th gen big brake kit works fine- but only for the front i believe.
post Jan 2, 2005 - 4:59 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE(shid @ Jan 2, 2005 - 3:41 PM)
[right][snapback]229113[/snapback][/right]
exactly. you can get the Rotora 4 or 6 piston big brake kit for the 7th gen front. 4 piston will run about 1400 and the 6 piston (or complete overhaul like I call it) will run about 2800. smile.gif
-Ti
post Jan 2, 2005 - 5:10 PM
shid
Joined Jan 8, '04
From LA
QUOTE(turboinduction @ Jan 2, 2005 - 9:59 PM)
-Ti
[right][snapback]229119[/snapback][/right]
I've always wondered if anyone on the site has done this- or if there are only horrible drawbacks to having such strong breaking power in the front and the stock brakes in the back
post Jan 2, 2005 - 5:13 PM
Hanyo
Joined Aug 16, '03
From Bay area
i think by the time they have the 4-6 piston brake kit they would have installed a break proportional valve.
post Jan 2, 2005 - 7:21 PM
shid
Joined Jan 8, '04
From LA
QUOTE(Hanyo @ Jan 2, 2005 - 10:13 PM)
[right][snapback]229124[/snapback][/right]
Oo whats that? (I have no clue about most suspension)
post Jan 2, 2005 - 7:25 PM
jgreening
Joined Jan 17, '04
From Illinois
Here's a start: The brakes are not part of the suspension system.
post Jan 2, 2005 - 7:27 PM
Ale_lock
From New York City, NY
Brake* proportional valve info.
post Jan 2, 2005 - 9:20 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
No... they usually require a new bigger badder master cylinder...
QUOTE(shid)
Brakes are typically front biased to prevent the rear-end from sliding out. The fronts do about 80-90% of the braking work... so you won't even feel it.
post Jan 2, 2005 - 9:21 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE(Hanyo @ Jan 2, 2005 - 4:13 PM)
if you would, explain why.
Since we have FWD cars, almost the entire load of the braking force is delivered to the front brakes STOCK. So to install a brake proportional valve to give the rear tires more traction under higher loads is pretty awkward. Granted, if I had a track car, this makes sense. But for the average street car with a big brake kit, the stock brake proportional valve will do just fine. Since OEM is typically balanced between the front and rear, and the front is pre-set for the most load and larger size, increasing the size and the caliper size will do nothing for unbalancing the system. The only thing I see is applying the maximized load possible on the new larger front components would stop the car much faster without the need to decrease the rear pressure because the rear load isn't that great to begin with. You'd want this if you installed a big brake kit all the way around the car (meaning rear) on a RWD car. The increased components in the rear would need to be adjusted so you still have most of the braking power in the front. Just my .02.
-Ti
EDIT: DAMN YOU KWANZA, everytime I tell ya - he beats me to it.
This post has been edited by turboinduction: Jan 2, 2005 - 9:26 PM
post Jan 2, 2005 - 10:09 PM
shid
Joined Jan 8, '04
From LA
QUOTE(jgreening @ Jan 3, 2005 - 12:25 AM)
[right][snapback]229160[/snapback][/right]
Thanks Jay. Thanks.
post Jan 6, 2005 - 12:48 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
lol^^^
i dont think the ST would be stopping near as well as the GT if the Kwanza and Ti were wrong wink.gif
even though most modern cars use disc anyways now
post Jan 9, 2005 - 12:45 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
arnt almost all Big Brake Kits only the front brakes.... Atleast im pretty sure...
post Jan 9, 2005 - 3:03 AM
Sev408
Joined Dec 4, '03
some cars you can get rears like the wrx and what not.
user posted image hows it taste motha f*cka
post Jan 9, 2005 - 3:18 AM
shid
Joined Jan 8, '04
From LA
and the evo.. mm
post Jan 9, 2005 - 3:58 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(Hanyo @ Jan 2, 2005 - 3:13 PM)
What i mean here is, If someone is going to the extreme to install 4-6 piston front brake system, they would have enough knowledge and understanding to install a system to balance the breaking power between the front and rear wheels.
Lo-Fi Version Time is now: January 10th, 2025 - 5:18 AM
