good idea or bad idea, some advice on buildin a non turbo 7a |
Jan 10, 2005 - 6:45 PM |
Enthusiast Joined Jun 22, '04 From portland OR Currently Offline Reputation: 0 (0%) |
just lookin to see if it would be a good idea to build up a 7a but not put on a turbo
-------------------- There Ain't No Party Like A Celica Party A Day Without Celica is Like a Day Without Sunshine. |
Jan 10, 2005 - 6:46 PM |
what do you mean? low compression? or souped up fuel system?
Jan 10, 2005 - 6:51 PM |
just wonderin if there are any draw backs to fully buildin the 7a as far as it will go
Jan 10, 2005 - 6:53 PM |
Enthusiast Joined Dec 13, '04 From St. Lucia Currently Offline Reputation: 0 (0%) |
I think he is wondering it it will be efficient to upgrade all internals, larger injectors, high compression pistons and running a very high redline instead of boosting... Basically making it a 4age type NA engine that has high end torque with very high redlines... It will work but i am not sure if it would be efficient or worth it. Someone else will have to tell you.
Jan 10, 2005 - 6:55 PM |
Enthusiast Joined Aug 26, '04 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
I think he means going with higher compression pistions, bigger cams, better fuel systsm, better ignition. Going for high HP with out useing forced induction.
Jan 10, 2005 - 6:56 PM |
yeah exactly what dabill said
This post has been edited by crazycel18: Jan 10, 2005 - 6:57 PM -------------------- There Ain't No Party Like A Celica Party A Day Without Celica is Like a Day Without Sunshine. |
Jan 10, 2005 - 7:13 PM |
Don't you already have the 4A-FE engine in your Celica instead of the 7A-FE? Or was that someone else from the meet?
Jan 10, 2005 - 7:14 PM |
thats dabill mines a 7a with low miles
Jan 10, 2005 - 7:20 PM |
QUOTE(crazycel18 @ Jan 10, 2005 - 6:56 PM) yeah exactly what dabill said [right][snapback]232192[/snapback][/right] Did anyone even see my post |
Jan 10, 2005 - 7:23 PM |
yes i saw it and thank you
cause that is what i meant -------------------- There Ain't No Party Like A Celica Party A Day Without Celica is Like a Day Without Sunshine. |
Jan 10, 2005 - 10:49 PM |
Enthusiast Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
Gotta come down to the shop man, they'll tell you everything that you want to know. From what ive seen down there, and talking the 5s is alot better engine for N/A purpose's well a cheap way togo, but if your allready changing the motor mounts why not a 3sge? its a beast at what 150-170ish hp?
DTE -------------------- I am a thief.
do not buy anything from me. |
Jan 10, 2005 - 11:13 PM |
Clips, he wants to know about building up the 7a cause he dont wanna do a motor swap. Also dont wanna run turbo cause turbo engines arnt usually that reliable for daily driving unless they came stock that way.
Jan 10, 2005 - 11:23 PM |
the 3sge is a NA engine. I would seriously start with buying forged piston rods and a forged crank shaft and some 11:1 compression pistons. You would want to get a 4age 20valve cylinder head and throttle bodies also and do a head swap since those engines run to 8300rpm redline and also do it on 11:1 compression pistons. You will basically be making a 7age hybrid engine with alot more power and with very reliable rods and crank shafts and a port and polish job on the head and the use of the 4age with high compression pistons, there is no reason why you cant rev that engine up to 9000rpm although ur tranny probrbably wont support those speeds but engine wise that is the best wya to go in fully building up an NA 7afe.
Jan 10, 2005 - 11:29 PM |
thanks for the info big thats what i was lokin for thank you very much and ill solve teh tranny isue when i come to it unless anyone want to clue me in on that one
Jan 10, 2005 - 11:34 PM |
Your best hope for a tranny for an A series engine that will stand that abuse would be the 4age 20 valve tranny. Since it handles the speed and power of the 1600cc 20 valve engine spinning at over 8000rpm then that would be your main candidate to withstand the extra. I am sure it is capable of handling alot more power since there are guys that turbo that engine and get alot more power out of it on that tranny. But the head swap on that engine would be a must since the 7afe has an FE fuel economy head and the GE head is a performance head and with the 5 valves per cylinder of the 20valve then efficiency is increased along with performance. Goodluck with all of this man.
Jan 10, 2005 - 11:38 PM |
yeah thanx for the vote of confidence and the info greatly appreciated
Jan 11, 2005 - 12:51 AM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
NA power is kwanza's area, ask him.
Jan 11, 2005 - 1:51 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
how much power do you want
you can only go so far with a 7afe before the general design of the economy head limits you and no, porting and polishing wont change that -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jan 11, 2005 - 3:11 AM |
You ask a very general question. I rather not indulge if you're not gonna ask anything direct. All i'm gonna say is:
biglipzit... you say quite a bit, and although some of is basic researched material and is stuff that has been said before... it doesn't make sense since you don't fully understand what you're talking about. That's all... nothing against you... but some things you are saying doesn't make any sense. I don't want to pick your posts apart... but know what you speak'eth before you preach'eth... ;] To make a comment... the 7AFE is only as worthwhile as you feel it is. Anybody telling you whether it's worth it or not, is their opinion... -------------------- "It's ok to be naked girl... I'm an artist!"
Jan 11, 2005 - 10:48 AM |
Agreed. Lucklily there is a wealth of knowledge on this web page about building such an engine.
Lo-Fi Version | Time is now: January 9th, 2025 - 6:33 PM |
