Erratic Idling, help me! |
Jan 10, 2005 - 10:47 PM |
Enthusiast Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
Hey everyone, my engine idles real strangely. I start the engine and everything runs fine and I can drive the car, but when I put the car into neutral or park, the engine revs up to 2k as its idle and then bounces between 2k-3k like mad. It sounds like my car is gonna tear itself to pieces!! Whats wrong? Im thinking it has to do with engine timing and if it is how can I adjust it?
Jan 10, 2005 - 11:18 PM |
Enthusiast Joined Dec 13, '04 From St. Lucia Currently Offline Reputation: 0 (0%) |
It probrably is timing i would think. I only ever adjusted the timing on a ka24de but that was done using a timing light on the main pulley and the timing marks and then twisting the distributor from left to right ti adjust the timing. Not sure if toyota engines are the same but i am sure google would have all the info for adjusting the timing on your specific engine.
lol just kidding about the pic!! |
Jan 10, 2005 - 11:33 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
i think there is an idle controller to when you put it in park. you have OBD I. does it throw a check engine at all.
Jan 10, 2005 - 11:51 PM |
nope no check engine lights at all. everything seems fine until I put the car into park or neutral and then it goes nuts
Jan 10, 2005 - 11:56 PM |
hard to say...maby something is wrong with the o2 sensor?
Jan 11, 2005 - 5:25 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
I doubt its timing, you could have a bad sensor or an air leak somewhere causing it to run lean and idle higher than it should.
Jan 11, 2005 - 11:17 AM |
Enthusiast Joined Oct 24, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
When did you last take it for a service? it can be dirty injectors/fuel filter or even sparks(though i doubt it)
Try driving it hard for 10-15 minutes to clean up the fuel system. I am no expert but my Curren had similar problem with high CO2 and the inspector told me to drive it hard for a few minutes and then come back, and what you know that fixed the problem. |
Jan 11, 2005 - 2:31 PM |
Well I just dropped my car off at Longo Toyota where my friend works so I guess I'll see whats wrong.
Jan 11, 2005 - 5:55 PM |
Enthusiast Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
I'm putting my money on Vaccuum leak.
Jan 11, 2005 - 6:34 PM |
Enthusiast Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Maybe the IAC vacuum pump is pushing air in?
Jan 11, 2005 - 11:35 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
its the Idle air control valve. Its a common problem with honda's and acura's, so I've seen it many times.
Jan 11, 2005 - 11:41 PM |
that was exactly what i was talking about but i couldn't remember the name.
Jan 13, 2005 - 2:43 PM |
Yep Junior and rjbibeau were right. My friend said my Idle Air Control Valve was messed up and I got it replaced and now everything is hunkey dory again
*Well everyone is kind right because I also got a tune up and got just about everything replaced * This post has been edited by hellsyphon: Jan 13, 2005 - 2:48 PM |
Jan 14, 2005 - 6:04 AM |
You suck for not mentioning me.. This is what I get for trying to help. Ha ha.. I kid.
Jan 14, 2005 - 8:51 AM |
Enthusiast Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
Mine does the same thing except it idles real low when im in neutral. like 100-200rpms.
where is the Idle air control valve |
Jan 14, 2005 - 9:59 AM |
Enthusiast Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) |
it's under the throttle body
Lo-Fi Version | Time is now: January 9th, 2025 - 6:16 PM |
