speed limiter |
speed limiter |
Jan 13, 2005 - 4:57 AM |
Enthusiast Joined Jan 13, '05 From Lithuania, EU Currently Offline Reputation: 0 (0%) |
Hi everybody,
I have got 6g celica JDM equiped, everything is OK with this car, but there is one problem. It has speed limiter at 185 km/h. Maybe somebody knows how to switch it off??? Thanks in advance. |
Jan 13, 2005 - 6:51 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
galu gale... Paciu laiku prisiregistravai
Welcome kaip sakant.. As long as i remeber, there is one wire that goes to your ECU, that sends speed signal. you can cut this wire, and put the switch on it, cuz if you totaly uncut it, your Engine check light will be on always, so then you really need top spead, just switch it off im i correct guys? here you will find more info about this thing.. www.evilspeed.com p.s. kaip gt4 laikosi? Be problemu? QUOTE(Aivarinis @ Jan 13, 2005 - 2:57 AM) Hi everybody,
I have got 6g celica JDM equiped, everything is OK with this car, but there is one problem. It has speed limiter at 185 km/h. Maybe somebody knows how to switch it off??? Thanks in advance. [right][snapback]233156[/snapback][/right] This post has been edited by doGGy: Jan 13, 2005 - 7:32 AM -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Jan 13, 2005 - 8:25 AM |
QUOTE(doGGy @ Jan 13, 2005 - 6:51 AM) galu gale... Paciu laiku prisiregistravai Welcome kaip sakant.. As long as i remeber, there is one wire that goes to your ECU, that sends speed signal. you can cut this wire, and put the switch on it, cuz if you totaly uncut it, your Engine check light will be on always, so then you really need top spead, just switch it off im i correct guys? here you will find more info about this thing.. www.evilspeed.com p.s. kaip gt4 laikosi? Be problemu? QUOTE(Aivarinis @ Jan 13, 2005 - 2:57 AM) Hi everybody, I have got 6g celica JDM equiped, everything is OK with this car, but there is one problem. It has speed limiter at 185 km/h. Maybe somebody knows how to switch it off??? Thanks in advance. [right][snapback]233156[/snapback][/right] [right][snapback]233159[/snapback][/right] Sveikas, gt4 kol kas vaziuoja, vis nera laiko prie jo giliau pasikuist. siaip kazkas bilda priekinej pakaboj ir niekas neranda kas... There is also some metal noise in front suspension, but I can't find where is the problem, maybe somebody can suggest some solutions.... This post has been edited by Aivarinis: Jan 13, 2005 - 8:27 AM |
Jan 13, 2005 - 12:22 PM |
year and GT or ST ? this is here
Jan 13, 2005 - 12:23 PM |
GT4
QUOTE(Batman722 @ Jan 13, 2005 - 10:22 AM) -------------------- Ex celica owner - just a guy from other side of the pond...
Jan 13, 2005 - 2:47 PM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
Hello. I wouldn't cut the wires if I were you.
I bought a Blitz speed delimiter for about 70 UKP and installed that. Works. BTW, it's limited to 180kph. Your speedo, like every speedo in the world, overreads. QUOTE(Aivarinis @ Jan 13, 2005 - 8:25 AM) There is also some metal noise in front suspension, but I can't find where is the problem, maybe somebody can suggest some solutions.... [right][snapback]233166[/snapback][/right] On a ST205? Let me guess, you've got 60-70000 miles on the clock and it makes a clonking noise if you hit a bump on a turn. It's also feeling a little vague. Suspension arm #2 and the figure of 8 (camber control) joint are worn. You might want to sit down before I tell you how much. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Jan 13, 2005 - 4:14 PM |
Mr_E, i was waiting for your replay Yup, his car has about 48k on speedo (if i remeber correctly)...
Well, now just go and tell him how much this gonna cost him...... Aivarai, laikykis, cia bus viena ish priezasciau kodel ash neipirkau GT4... QUOTE(Mr_E @ Jan 13, 2005 - 12:47 PM) Hello. I wouldn't cut the wires if I were you. I bought a Blitz speed delimiter for about 70 UKP and installed that. Works. BTW, it's limited to 180kph. Your speedo, like every speedo in the world, overreads. QUOTE(Aivarinis @ Jan 13, 2005 - 8:25 AM) There is also some metal noise in front suspension, but I can't find where is the problem, maybe somebody can suggest some solutions.... [right][snapback]233166[/snapback][/right] On a ST205? Let me guess, you've got 60-70000 miles on the clock and it makes a clonking noise if you hit a bump on a turn. It's also feeling a little vague. Suspension arm #2 and the figure of 8 (camber control) joint are worn. You might want to sit down before I tell you how much. [right][snapback]233322[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Jan 14, 2005 - 9:20 AM |
QUOTE(doGGy @ Jan 13, 2005 - 4:14 PM) Mr_E, i was waiting for your replay Yup, his car has about 48k on speedo (if i remeber correctly)... Well, now just go and tell him how much this gonna cost him...... If it's the Fig8's and lower arms...... .....in UK pounds, £80 for the fig 8s, £200 for the lower arms. Plus fitting. Per side. I just rebuilt the entire suspension. -------------------- JDM ST205
Jan 14, 2005 - 9:34 AM |
QUOTE(Mr_E @ Jan 14, 2005 - 9:20 AM) QUOTE(doGGy @ Jan 13, 2005 - 4:14 PM) Mr_E, i was waiting for your replay Yup, his car has about 48k on speedo (if i remeber correctly)... Well, now just go and tell him how much this gonna cost him...... If it's the Fig8's and lower arms...... .....in UK pounds, £80 for the fig 8s, £200 for the lower arms. Plus fitting. Per side. I just rebuilt the entire suspension. [right][snapback]233681[/snapback][/right] understood, next week I'll try find were is the problem p.s. have a nice weekend |
Jan 15, 2005 - 6:18 AM |
QUOTE(Aivarinis @ Jan 14, 2005 - 9:34 AM) understood, next week I'll try find were is the problem p.s. have a nice weekend [right][snapback]233684[/snapback][/right] You too bud. If you're going to do the job, drop me a PM and I'll give you the details of where I got my bits from. Might save you a few beers worth. Significantly cheaper than Toyota. -------------------- JDM ST205
Lo-Fi Version | Time is now: January 10th, 2025 - 1:51 PM |
