Common 6th gen problems |
Jan 21, 2005 - 11:46 AM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
QUOTE(blackbullet @ Jan 15, 2005 - 8:36 AM) but guys..hes talking about a GT four..hehe...anyways... i have oil burn and sorry antenna problems on mine... [right][snapback]234017[/snapback][/right] i had bad antenna problems when i bought mine, i just disconnect the piece of crap.. now i'm good to go! -------------------- |
Jan 22, 2005 - 3:22 PM |
Enthusiast Joined Nov 1, '04 Currently Offline Reputation: 1 (100%) |
If yur gettin a convertible....
This is what happened to mine, and I've talked to a few others who had this problem aswell, but the switches that bing down the back windows loose power and wont work.. Soemthin like that... Not quite too sure.... AS far as burning oil... my car desn't burn a whole heck of a lot... It actually burns real clean too. REAL clean... Its kinda crazy how clean the oil is in my celica Also another prolblem that might be comon is the antenna... Mine gets all pissy and will make a buncha noise at me... Then I have no clue if this is common... But the CV-joint... (basically an axel) Somethins up with mine, but imnot too sure if its common or not... BUt those are basic problems tat i got... Other than that, the Celica is all good This post has been edited by CelicaBuddy: Jan 22, 2005 - 3:25 PM -------------------- 2003 Nissan Murano SE |
Jan 22, 2005 - 9:09 PM |
Enthusiast Joined Jun 4, '04 From DeKalb Illinois Currently Offline Reputation: 0 (0%) |
Umm yeah the antenna is a big problem haha.. mines either stuck down or stuck half way up. Other then that i have to say that iv never experienced any oil burning problems
Jan 22, 2005 - 11:45 PM |
Enthusiast Joined Jun 2, '03 From Annandale VA Currently Offline Reputation: 0 (0%) |
alot of problems it seems with 02 sensors
Jan 23, 2005 - 11:00 PM |
Enthusiast Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) |
for me its seems to be like most of u guys teh buring of the oil i have to at least use 2 bottoles of oil b4 i even have to change the oil again...this is using synthetic...also my car soemtiems shakes at idle liks deptending on the wheather this happens mosly during teh cold
Jan 24, 2005 - 4:47 PM |
Enthusiast Joined Dec 2, '04 From Surrey, England Currently Offline Reputation: 0 (0%) |
Mine doesn't burn oil as far as i can tell, does tend to get through it though (probably more my driving than anything ) Antenna is fine, a little wd40 doesnt go amiss tho. BUT i do get a real nasty squeel when i fire it up in the mornings and go full lock to get off my driveway. Heard this is probably the power steering, anyone know how to silence this cos it is kinda embarrassing, makes your car sound like an old banger, just cant have that!! How about fitting a new power steering belt? Other than that, these are sound cars and you could do far worse!!
Jan 25, 2005 - 5:22 AM |
Enthusiast Joined May 7, '04 From Leeuwarden, Netherlands Currently Offline Reputation: 0 (0%) |
You can't do anything about it. The sound is created by valve's inside the pump.
Only problem I've seen so far (20000Km) front brakes (pistons) jam once in a while. |
Jan 25, 2005 - 5:57 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
CV joints are gonna be a common problem in all front wheel drive cars. I've replaced both of mine they were both factory, at about 110k miles. Just after awhile the rubber gets old and rips easy.
Jan 25, 2005 - 8:21 AM |
havent read the whole thread .. but one problme most everyone seams to have..one GT's ... Holding idle on cold starts..
Jan 25, 2005 - 11:57 AM |
Enthusiast Joined Jun 23, '03 From Hialeah, Florida Currently Offline Reputation: 0 (0%) |
Most common problem was CV joints, which is an easy fix though, on my 6gc and 5gc they have been changed, also the starter is acting up, and the cold start on the power steering that happens to the 6gc too. and the worste problem of all, its hard to do your business in the backseat, not too big
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:45 PM |
