> why does my car sound like this, deeper sound on stock?
post Jan 13, 2005 - 1:24 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
ok, i noticed about a month or so ago that my car all of a sudden sound a lot deeper in its tone... like i have an exhaust or something... i have not engine mods at all, but the car is at about 176k mi. what could be the problem? im kinda worried because its my only means of transportaton and if its a big problem. i want to fix it now and avoid any further damage, im a broke college student who doesnt have much money to fix, so the earlier the better thanks all... this site works wonders
post Jan 13, 2005 - 1:26 PM
maybe an exhaust leak, cant think of anything that would lower or modify your exhaust sound.
post Jan 13, 2005 - 2:37 PM
Newbie
Joined Nov 3, '04
From Colorado
Check your resonator, see if all of the intake pipings are connected.. While you are at it, take the resonator out anyways.. Oh yeah.. Check the intake piping where it connects to throttle plate too. If not, you can always check exhaust pipings for leaks and gasket for worn spots or gaps.
post Jan 13, 2005 - 4:21 PM
spunky393
Joined Apr 22, '04
From illinois
this is common for a lot of toyota's. The flex pipe will wear and and finally a small hole will develop. The flex pipe is inbetween the immediate exaust piping and the cat (the cat under the car, not the first one). It's a steel braided pipe, and everyonce in a while, i'll run into toyota's with the exact same problem. It's cheap if you just get a knock off version of the flex pipe, and it works just as well. DON'T GO TO TOYOTA
Lo-Fi Version Time is now: December 4th, 2024 - 3:24 PM
