Tire size??, Whats the biggest? |
Mar 27, 2003 - 4:47 PM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
Whats the biggest rims/tires can you put on w/o rubbing?? Just got it and I'm looking at some 17s. I want to know if i have to worry about rubbing thanks.
Mar 27, 2003 - 4:52 PM |
Enthusiast Joined Mar 22, '03 From NH, USA Currently Offline Reputation: 0 (0%) |
I'm pretty sure the biggest is 18.
Mar 27, 2003 - 7:16 PM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
someone on here is rollin on either 19s or 20s.
As long as you got wheelwell space then you can fit a tire in there. You can always buy spacers to make you rim stick out a little more incase you put on like 22s and they rub. |
Mar 27, 2003 - 9:27 PM |
1equizitcelica has 19's
and dude don't buy spacers to make your well stick out... I would 17"s say look the best |
Mar 27, 2003 - 11:08 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
17s or 18s look the best, 1ezquizitcelica goes thru at least like 5 pairs of 19s and 20s a year, but he has hydros..im guessing 19s is the general limit for a celica
Mar 28, 2003 - 2:10 AM |
Enthusiast Joined Nov 8, '02 From Narragansett,RI Currently Offline Reputation: 0 (0%) |
I just got 18's and there is a little bit of rubbing when I cut the wheel all the way to the right. The tire size has alot to do with rubbing. I have a 40 series tire, but if the roads around you are not that bad, go with 35's.
Mar 28, 2003 - 10:09 AM |
so 17s will fit fine, i don't want 2 go bigger than that.
Mar 28, 2003 - 10:43 AM |
my sig is w/ 17"s and a 1.5" drop...you can fit 18"s...but ya risk denting rims if your roads arnt good..
13.6@108MPH, 5SFTE Powered |
Mar 29, 2003 - 7:15 AM |
Enthusiast Joined Mar 17, '03 From Quebec Currently Offline Reputation: 0 (0%) |
Even in 17, make sure you get quality rims if you don't want to roll on with square rims in a month....I spent close 500$ cdn in wheels repair last year with 17 Mille Miglia ...The roads are pretty bad around here too.
Mar 30, 2003 - 4:06 PM |
Enthusiast Joined Aug 29, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
get 17's with a 215/45 tire...perfect size
Mar 30, 2003 - 6:03 PM |
Enthusiast Joined Nov 11, '02 From Ohio Currently Offline Reputation: 0 (0%) |
I would agree...yours look perfect on your celi....what kind of tire did you get?...just curious... |
Mar 31, 2003 - 4:07 PM |
The last rims that I had were 17's. I had 215/45's with them and I had no problem with rubbing. If your gonna get 17's, I would suggest this tire size.
Mar 31, 2003 - 6:45 PM |
What is a good size so i don't mess up my speedometer? 17s & 16s
I'm looking at 17s w/ 205/40 or 16s 205/40 or 225/50 thanks |
Mar 31, 2003 - 7:03 PM |
Go see on www.tirerack.com
they give you the right size. In 17, it's 215-40-17, 16 : 205-50-16, 15:205-55-15 |
Mar 31, 2003 - 10:03 PM |
All i see is 215/45/17
Apr 1, 2003 - 6:12 AM |
Huuhh ??
Optional 17" Sizes for 1994 Toyota Celica GT Description Size Optional 17" 215/40-17 |
Apr 1, 2003 - 7:05 AM |
Enthusiast Joined Feb 18, '03 From UK Currently Offline Reputation: 0 (0%) |
Ive seen 19s on a celica VERY nice, but he had like 350bhp to go with it!
Im gonna get 18s soon, would like a nice width tire on the back, any suggestions on size for the rear, would 245s fit? or could i go bigger? |
Apr 1, 2003 - 9:21 AM |
not on tirerack, I'm looking at a rims & tire deal, will i have any problems with 215/45, like changing my speed?? I'll b going thru new orleans alot this fall so i need to know the right speed so i don't get any tickets. |
Apr 1, 2003 - 7:19 PM |
Héhé...
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 215/40-17 3.4in 11.9in 23.8in 74.7in 848 0.0% 215/45-17 3.8in 12.3in 24.6in 77.3in 819 3.6% Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 205/55-15 4.4in 11.9in 23.9in 75.0in 845 0.0% 215/45-17 3.8in 12.3in 24.6in 77.3in 819 3.1% |
Apr 1, 2003 - 11:58 PM |
Enthusiast Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
I wanted to get 17's but think that realisticly 16's are lighter and would be better since the 7AFE is a bit underpowered to say the least. Can i get 215 wide 16" wheels because other than just looks there is no benefit from bigger wheels unless you have a good bit of power. Im just looking for a wider wheel and think I can save money by going with 16" rims and matching tires.
Lo-Fi Version | Time is now: November 28th, 2024 - 11:41 AM |
