> Request for Toyota Harness Information
post Jan 14, 2005 - 9:10 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Something similar to this would be nice.
ST205 ECU Pinout:
http://img.photobucket.com/albums/v132/wan...05ecupinout.jpg
This post has been edited by WannabeGT4: Jan 18, 2005 - 7:24 PM
post Jan 15, 2005 - 12:13 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Found these for the 7AFE. Now I just need them for the 5SFE.
http://img.photobucket.com/albums/v132/wan...t4/Pinout_1.jpg
http://img.photobucket.com/albums/v132/wan...t4/Pinout_2.jpg
This post has been edited by WannabeGT4: Jan 18, 2005 - 7:25 PM
post Jan 15, 2005 - 3:31 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I have a couple... but my scanner is crapping all over itself. I found thisone somewhere and saved it...
http://home.earthlink.net/~kwanza26/ToyTCCS_Pins_5S-FE.gif
Better click it rather than post it... to save us poor dial up dudes... =[
post Jan 15, 2005 - 11:51 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Thanks Kwanza. Is that for the 5SFE in the 5th gen celica? cause the number of pins doesn't match the schematic I've got. 6th gen 5sfe has 26,16, and 22 pins on the connectors.
This post has been edited by WannabeGT4: Jan 19, 2005 - 7:43 PM
post Jan 16, 2005 - 12:09 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(WannabeGT4 @ Jan 16, 2005 - 4:51 AM)
Thanks Kwanza. Is that for the 5SFE in the 5th gen celica? cause the number of pins doesn't mach the schematic I've got. 6th gen 5sfe has 26,16, and 22 pins on the connectors.
[right][snapback]234242[/snapback][/right]
It might be actually. I got it off of celica.net a while ago. You're looking for the OBDII pinout right?
post Jan 16, 2005 - 1:48 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Actually I'm looking for any information available. So far I have pinouts for:
AE86 4AGE (Scan)
AE92 4AGZE (HTML table from website)
AE101 4AGZE (HTML table from website)
AE111 4AGE (Scan)
AT200 7AFE M/T (Scan)
AT200 7AFE A/T (put together from schematics)
ST205 3SGTE (Scan)
ST185 3SGTE (Scan)
ST165 3SGTE (HTML table from website)
SW20 3rd gen 3SGTE (Scan)
ST204 5SFE A/T (put together from schematics)
AW11 4AGE (Scan)
AW11 4AGZE (Scan)
?????? 5SFE (scan that you posted)
I Still need:
ST215 3SGTE
ST204 5SFE M/T
ST203 3SFE W/ AWS
ST202 3SGE/3SFE W/O AWS
SW20 2nd 3SGTE
This post has been edited by WannabeGT4: Jan 18, 2005 - 7:12 PM
post Jan 16, 2005 - 12:47 PM
i started a thread a while back about swap wiring and scaned in a lot of the diagrams i had from my books...
http://www.6gc.net/forums/index.php?showto...&hl=swap+wiring
post Jan 17, 2005 - 1:47 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Thanks lagos.
Do you have a chart for the main 5sfe fusebox plug "EA1" that the 3SGTE harness needs to be spliced into? I assume it was posted by outsider in your previous post but the link seems to be broken.
Also, could you explain a little more about the 3 or 4 interior plugs that need rewired? Did that just consist of repinning the the 3rd ecu connector (22pin)?
post Jan 18, 2005 - 12:13 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
hey i need the aw11 4agze pinout and the ae86 4age pinout if you have them can you post them?
-DMC
post Jan 18, 2005 - 12:25 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(thedevilmaycrie @ Jan 18, 2005 - 11:13 AM)
-DMC
[right][snapback]235142[/snapback][/right]
Well I'll see what I can do when I get home tonight (5:30ish). I have some generic ones that don't say what they're to but they do specify if they're MAP or AFM so that should help out at least a little bit.
post Jan 18, 2005 - 12:33 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
-DMC
post Jan 18, 2005 - 6:45 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
4AGZE info
http://www.club4ag.com/faq%20and%20tech_pa...11%204A-GZE.htm
4AGE
http://www.club4ag.com/faq%20and%20tech_pa...E86%204A-GE.htm
Other good links can be found here.
aw11 4agze ecu
ae86 4age ecu
post Jan 18, 2005 - 6:47 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
These are the Generic ones I had on my PC.
AFM:
http://img.photobucket.com/albums/v132/wan...s_4A-GE_AFM.gif
MAP:
http://img.photobucket.com/albums/v132/wan...s_4A-GE_MAP.gif
This post has been edited by WannabeGT4: Jan 18, 2005 - 7:26 PM
post Jan 19, 2005 - 7:45 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(WannabeGT4 @ Jan 17, 2005 - 12:47 PM)
Thanks lagos.
[right][snapback]234732[/snapback][/right]
?????????????? Any help here buddy???????????
Lo-Fi Version Time is now: January 10th, 2025 - 6:53 AM
