new clutch.. what kind and where?, my stock clutch is bad |
Jan 14, 2005 - 11:29 PM |
Enthusiast Joined Jan 5, '05 From Santa Ana, OC So Cali Currently Offline Reputation: 0 (0%) |
The clutch in my celly is bad now and i need a replacement quick..
i am new to this so i was wondering if i could get opinions as to wheter i should just get a replacement stock clutch since i don't plan on putting a turbo on my car... or if i should spend the little extra cash to get a sport/racing clutch since i do drive mostly pedal to the metal.... i need some ideas as to what kinds of clutches i should be looking at... BTW i have a 99 GT celly.. oh and one more question about how much does it cost to pay someone to install a clutch? thanks for the help guys -Chris |
Jan 15, 2005 - 12:57 AM |
Enthusiast Joined Aug 26, '04 From St. Cloud, Minnesota Currently Offline Reputation: 0 (0%) |
A stock clutch is perfect for any kind of driving. If you had a lot of mods to your car then yeah go for an aftermarket clutch, but I don't se why you would since your car is mostly stock(assuming).
Jan 15, 2005 - 12:59 PM |
well i'm considering exedy.. or there is some kit from NAPA.. beck arnley kit that cost 238 beck arnley clutch
or i can get a clutch from clutchmasters... the stock OEM one for 168clutchmasters stock help... -Chris |
Jan 15, 2005 - 2:15 PM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
clutchmaster stock would be fine if you are not planning on doing anything. I just recently ordered the ACT clutch kit, it's about a stage above stock. Item # TY2-HD00 at www.clutchcityonline.com
I've heard good things about it, but i'm also planning on performance tuning in the near future, so that's why i went with this. It has a 37% increase on hold i'm pretty sure. -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Jan 15, 2005 - 2:18 PM |
and don't worry about your flywheel. Just get it resurfased (spelling) which the shop will do for you ($35 bucks or so). Also, i forgot to add, the guy that does my work around here charges a strict $350, no matter how long or how short. (considering the way our cars are set up, it'll be long)
Jan 15, 2005 - 9:14 PM |
Enthusiast Joined Jul 11, '04 From CR, Iowa Currently Offline Reputation: 0 (0%) |
I got a stage I centerforce clutch form www.dualfriction.com and installed a couple months ago and i really like it. Its a little different feeling from stock, it took some getting used to, but thats my recomendation. My install was $300 and about $130 for the clutch and t.o.b.
Lo-Fi Version | Time is now: January 10th, 2025 - 10:57 AM |
