> Weird noice right after acceleration, help i guess?
post Jan 15, 2005 - 3:19 PM
spunky393
Joined Apr 22, '04
From illinois
I don't know what i'm goign to get out of this. But yesterday, i would step in it, go thourgh 1st, 2nd, and 3rd, and let off the gas and i would here what would sound like a loud retraction of a weight. For example of what i mean, anybody that's ever gone to a tractor pull, when the tractor starts going, the weight moves closer and closer to the tractor on the huge sled, furthermore, causing a huge weight gaine on the rear wheels of the tractor. Well, the sound i'm hearing sounds like that weight going back down to the normal position it was in.
anybody ever had this happen (and it's probably not just in 3rd gear, i just don't like the jerk response when i let off the pedal on the second gear in high RPM's)
lets hear it 6GC
post Jan 15, 2005 - 11:09 PM
diagnosis: motor mount.
post Jan 16, 2005 - 1:44 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
after 1st and 2nd i get a loud noise comming from the front but its commin from my axels they both need to be replaced so i would check your becouse it sounds like you have the same prablem as me... either that or as super said motor mounts are the only two i can think of.
Lo-Fi Version Time is now: November 28th, 2024 - 6:39 PM
