3 Pages V  < 1 2 3 >
> well i found out my smoking problem....., not good...not good at all
post Jan 18, 2005 - 6:34 PM
forkee
Joined Nov 13, '02
From So Cal
ok then, ill take the hks ones off of u. as for the parts, i can just go with u to the store and buy em there, so u can see what else will be needed. does that work? smile.gif
post Jan 18, 2005 - 6:44 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
yeah of course just lemme know when you wanna do this... and how soon you want the pistons...
-DMC
post Jan 18, 2005 - 6:50 PM
forkee
Joined Nov 13, '02
From So Cal
well my free time is limited to mondays and wednesdays after 5. thats pretty much it unless i request a sat ur sunday off. whats good for you? like i said i really want to get the ball rolling on this, cuz its been smoking forever. so ur gonna put everything on for me? the new pistons and everything? biggrin.gif ill have to pay you for labor. tongue.gif
post Jan 18, 2005 - 6:53 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
check your pm
-DMC
post Jan 18, 2005 - 7:10 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
scratch that call me at home 760 231 1166 at around 500
-DMC
post Jan 18, 2005 - 8:59 PM
forkee
Joined Nov 13, '02
From So Cal
so with the hks agze pistons, my compression will be around the 8.5:1 that i want, correct?? i read somewhere that when u put it in the 7a it raises it to 11 cuz the block is smaller? confused.gif confused.gif
post Jan 18, 2005 - 9:47 PM
i was just about to get to that
4AGZE pistons raise a 7afe/7afte/7agte/7agze
compression by a good amount
the specific amount is UNKNOWN
but you are right doggy and edo have estimated 11.5ish i think
not exactly sure of the exact number but its 11 sumthing on Edo's
modified 7afe
now personally forkee i wouldn't go with the 4agze pistons that devil is
going to sell you(nothing against you devil) since you will have an unknown CR which isn't good on a f/i motor
especially the 7 since its picky
i'd go to arias and get a set of pistons made for you personally maybe run a GB for us
thats my opinion and the best way to go about it.......saftly
just get some rings for now and vavle seals
then when you have the right pistons but them in
oh and the 4agze pistons are different in 1 aspect
that i don't think was told to you
the wrist pins are different
one motor has "floating" wrist pins
and the other has "locking: wrist pins
i do believe that is the proper term
so that has to be modified
just don't know how hard it is
post Jan 19, 2005 - 1:45 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Well, suggesting NOT to go with gze pistons was stupid.....
Cuz you dont know the issues and etc.
GZE pistons and 7A will give you 10.8:1 CR. Edo, who used ARIAS 8.5:1 CR pistons in his reworked engine got 11.02:1 CR, cuz of the bigger bore (82mm). And forkee is going with the stock bore. So he will get the 10.8:1
In this case, you have to raise your head. 1.6mm will give you about 9.5:1 basicly back to stock. if you gonna use 2mm one, you will get 9:1 (9.1 to be exact smile.gif)
Metal head gasket for paradise raising will cost you about 125$ shipped in 2mm. But still you can find HKS head gasked for the same price or maybe lower, depends on the heigh you are looking.
Only thing, that Rods needs to be reworked that the wrist pin floated fully, and this will give you the second chance if the wrist pin is locked in the pistons or the rod, you wount through the rod out of the block, cuz in one of the 2 places wrist pin will be still free.
And reworking is not that big, cuz both pins are 20 mm, so only the small very small amount on rod insert need to be machined, swo any good machine shop will do this.
I know, i was sceard to do this at first then i started collecting info, but after some time, i know that this will work, and it will give you stronger pistons for really reallly low money, cuz GZE pistons are FORGED.
But be sure to get the right bore pistons, 7A bore is 81 mm
And if some one wants to recalculate the CR ratios, here are the numbers:
Bore 81 mm
Stroke 85.5 mm
Cumbursion chamber 36 cc
7AFE dished piston 10 cc
and if CR is at 10.8 with gze pistons, and they are parcticly flat (about 4 cc) so you can get all the number you need from what i gave ya.
QUOTE(playr158 @ Jan 18, 2005 - 7:47 PM)
modified 7afe
[right][snapback]235377[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Jan 19, 2005 - 3:39 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Wow, bryan you are so fricken nice. its hard today to find people as generous as you.
This post has been edited by CheesyLobster: Jan 19, 2005 - 3:39 AM
post Jan 19, 2005 - 10:20 AM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
lol thanx... i think...? lol if a friends in need you should always help if you can... i know mechanics work so i can help like that... doggy know specs, and thats how he helps... coomer made this site thats how he helps... the point is guys we are a family... we should always want to help whenever we can...
-DMC
post Jan 19, 2005 - 12:00 PM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
smile.gif you guys are so awesome
post Jan 19, 2005 - 12:06 PM
FallenHero
Joined Dec 26, '02
From Alabama
I have a link where you can get the HKS head gaskets for $95 + shipping. and I think the company is in Cali so you won't have any trouble there. I am at school right now though... I will try to post it up tonight. The only thing is that ALL HKS gaskets are for 82mm bore. Now, they are fine to use on the 81mm, it will just Marginally drop the compression... basically not even enough to measure though. It will be a boosing machine with all the parts we have mentioned. Shame you can't habve the rods re-worked before the install. frown.giffrown.giffrown.gif
post Jan 19, 2005 - 12:39 PM
forkee
Joined Nov 13, '02
From So Cal
awesome, so "project 4agze pistons" is scheduled for sunday. its going to be a one day project, since i absolutely have no other time to do it. so bryan, u still feel up to it? we are getting a 2mm head gasket right? and do u know how to rework the rod deal with the pins? hopefully the headgasket we get will be the right one. thats pretty much my only concern right now (well besides the rods). i wont be pushing past 9 psi, so everything should be kosher, right guys??
p.s.- this will make a great addition to the search function for anyone looking this up in the future, since i couldn't really find anything prior. biggrin.gif
post Jan 19, 2005 - 12:45 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
yeah im game... today ill call for the parts from toyota...
-DMC
post Jan 19, 2005 - 1:05 PM
nik
Joined Sep 30, '02
http://www.6gc.net/forums/index.php?showtopic=18144&hl=7afte
this had some good info
post Jan 19, 2005 - 1:25 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
fallen- i need the contact info for the head gasket asap
forkee- trd doesnt make a metal head gasket for the 7afe... the total cost of parts will be 235 + tax the rings are the most expensive at over $150... lemme knwo what you wanna do so i can order them so they can be in by friday...
-DMC
post Jan 19, 2005 - 2:51 PM
forkee
Joined Nov 13, '02
From So Cal
ok well if we cant get the proper 2mm head gasket to lower the cr for the 4agze pistons, id rather just replace the stock piston rings for now. that way its not such a huge hassle.
post Jan 19, 2005 - 3:54 PM
FallenHero
Joined Dec 26, '02
From Alabama
http://nipponpower.com/engine/gasket/cometic_hp.html this is a nippon power head gasket. they make one in 81mm. The thickness I have not computed though
I am looking for the HKS as I type
http://www.optionsauto.com/index.htm?paren...57&deptid=10706
$111
2mm
http://www.optionsauto.com/index.htm?stock...=HKS-2301-RT010
This post has been edited by FallenHero: Jan 19, 2005 - 3:56 PM
post Jan 19, 2005 - 4:04 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
well forkee make your choice
-DMC
post Jan 19, 2005 - 4:18 PM
nik
Joined Sep 30, '02
COPPER HEAD GASKET 7AFE
you can get .8mm, 1.1, 1.27,1.57,2 mm ,and 2.4 mm Made for the 7AFE
This post has been edited by nik: Jan 19, 2005 - 4:21 PM
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: January 10th, 2025 - 6:10 AM
