well i found out my smoking problem....., not good...not good at all |
Jan 19, 2005 - 5:38 PM |
QUOTE(nik @ Jan 19, 2005 - 2:18 PM) COPPER HEAD GASKET 7AFE i see your metal and raise you a copper you can get .8mm, 1.1, 1.27,1.57,2 mm ,and 2.4 mm Made for the 7AFE [right][snapback]235698[/snapback][/right] lol.. I don't know anything about copper head gaskets. but hey, if the price is right... |
Jan 19, 2005 - 6:50 PM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
ok lets go with the copper 2.4mm thick(.093") 7afe headgasket, but their bore size is 84mm. so itll have to be special ordered for 81mm bore size. does that sound about right?? this should be perfect for the 4agze pistons, correct??
Jan 19, 2005 - 8:29 PM |
sounds good to me. Should be one hell of a set up. If you coudld do something with the rods you could about run 12psi like I once wanted. Either way 8-9 will be hella nice.
Jan 20, 2005 - 1:35 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
I wount suggestr you going more then 2mm. 9:1 CR is practicly perfect for turbo aplication. 2.4mm i can tell how much CR will be dropes, but it will be below 9 for sure... Go with 2 mm atleast...
QUOTE(forkee @ Jan 19, 2005 - 4:50 PM) ok lets go with the copper 2.4mm thick(.093") 7afe headgasket, but their bore size is 84mm. so itll have to be special ordered for 81mm bore size. does that sound about right?? this should be perfect for the 4agze pistons, correct?? [right][snapback]235783[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Lo-Fi Version | Time is now: January 10th, 2025 - 6:16 AM |
