dash warning light !!, what is it ??? |
Jan 24, 2005 - 3:39 AM |
Enthusiast Joined Jul 12, '03 From centre of universe, nicosia, cyprus Currently Offline Reputation: 0 (0%) |
QUOTE(popstar @ Jan 24, 2005 - 11:26 AM) Hmmm now that's a good idea... it's a jap' import so there's a good chance it's parkinging light fuse, plus it's on the drivers side thanks...... now to play hunt the fuse <:) unless you havew any idea's where that is ????? [right][snapback]237511[/snapback][/right] fuse box is in the engine bay as far i can remember -------------------- |
Jan 24, 2005 - 5:09 AM |
Enthusiast Joined Nov 6, '03 From Campbellsville, Ky. Currently Offline Reputation: 0 (0%) |
QUOTE(popstar @ Jan 24, 2005 - 1:11 AM) Ok guys, I'll re check all my rear lights again ! yeah recycle that's the one i mean, it's not on any other celica, i check in over the weekend so it could just be a loose wire even..... Gas65..... why ??? [right][snapback]237454[/snapback][/right] Us Americans don't have that warning light so I was giving you ideas as to what it might be. I used to own a Honda that had a warning light that would kick on when you hit a bump if the hatchback was'nt shut down tight. |
Jan 24, 2005 - 5:14 AM |
Enthusiast Joined Nov 24, '04 From Moscow, russia Currently Offline Reputation: 0 (0%) |
Thank's gas65, now i see where your coming from, yeah could of been an idea
recycle that's where i thought it would be, blin it's a bit like looking for a pin in a hay stack there's lots of extra boxes and fuses under my hood .......... i'll let you know how it goes, after i check it tonight ...... -------------------- Life is for living, and you don't get a second chance Take care now !! |
Jan 24, 2005 - 5:50 AM |
hmmm 4 fuse boxes under hood and two in cockpit .........
one by hood release looked promising, but all fuses OK and nothing for a park light !!!!!!!!!!!!! re checked lights again, all ok at back, just side light out <:( guess i need a trip to get wiring checked ................ -------------------- Life is for living, and you don't get a second chance Take care now !! |
Jan 29, 2005 - 4:23 PM |
Enthusiast Joined Oct 24, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
I had the same problem on my GT4 when i changed my rear lights. if there is no light when you start up the car and when you press the brakes the light come on, then one of you brake light bulbs is burnt. more specifically, the bulb has 2 springs that light up. one is the low that lights up when you turn on your lights and the other spring in the bulb is the one that makes a brighter light when you brake. When you start up the car its ok, but when you press the brakes, the burnt light triggers the sensor to indicate that you have a burnt brake light bulb.
Jan 29, 2005 - 7:21 PM |
Enthusiast Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
Neoklis is right. The rear light bulbs have 2 elements. One parking light and the other lights when braking. The 2 elements have different resistances and sizes.It is
possible to still get a brake light warning light after you've replaced a blown bulb. This is because the bulb can be fitted accidentally so the elements end up on opposing circuits. If you've changed bulbs recently and still have the dash light just switch the bulb around 180 degrees.This is the case for jap cars, don't know if it applies to US models. |
Jan 30, 2005 - 7:03 AM |
its impossible to put the lamp wrong. IMPOSSIBLE.
the 2 pins on the side have different hights and can not be put any other way -------------------- |
Lo-Fi Version | Time is now: November 24th, 2024 - 11:21 AM |
