5 Pages V   1 2 3 > »
> 7afte pistons and rods, time to rebuild
post Jan 21, 2005 - 11:03 AM
nik
Joined Sep 30, '02
Psi Racing had the 7afte that ran 14.4 on 14 psi they have somw stuff for the 7afte people out there.
Hey nik
Whats up, well for starters no company actually stocks it, we would have to get them custom made, I would need a factory piston from you and then I would send it out, to my piston manufacturer and they will duplicate it, in whatever compression ration I wanted, the rods I think they should have on file, so those we shouldnt need a core, just let me know exactly what you want to do.
Thanks,
Brendan Alvarez
PSIRacing
so far also depends on final price
1. NIK
2. Doggy
3. Edo
4.trdevelopment
post Jan 21, 2005 - 2:20 PM
edo17982
Joined Dec 21, '02
From Italy
post Jan 21, 2005 - 5:00 PM
provided no huge pricing
post Jan 21, 2005 - 11:13 PM
d3monc3lica
Joined Aug 19, '04
From Maine
count me in, also if the price isnt outrageous
post Jan 24, 2005 - 12:29 PM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
Pauter have 7afe rods listed (I have the part number) and for the pistons , we have just to know what compression the 4agze give with the 7afe head .
Claude
post Jan 24, 2005 - 2:22 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Pauter charge hell to much, and they are not the best for the money... About pistons GZE pistons make 10.8:1 CR in stock 7A
QUOTE(frotou @ Jan 24, 2005 - 10:29 AM)
Claude
[right][snapback]237638[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Jan 24, 2005 - 4:28 PM
frotou
Joined Jan 9, '04
What is the best for the 7a ? Crower pro billet ? Forget standart crower and eagle .
post Jan 24, 2005 - 4:31 PM
wouldn't you want those(4agze) pistons in a NA 7afe more then in a 7agte? or 7afte? cause its better for high compression in NA
post Jan 25, 2005 - 1:24 AM
doGGy
Joined Oct 28, '02
Have you ever heard about HOW TO LOWER your CR?
QUOTE(playr158 @ Jan 24, 2005 - 2:31 PM)
[right][snapback]237766[/snapback][/right]
post Jan 25, 2005 - 1:26 AM
doGGy
Joined Oct 28, '02
It is better to go with Crower rods.. Even they make the custom ones, price will be practicly the same as pauter, but Crower rods are better IMHO... And i read lots of good info on them...
Nik, so hows with the PSI racing going? Are they gonna give some estimates?
QUOTE(frotou @ Jan 24, 2005 - 2:28 PM)
[right][snapback]237762[/snapback][/right]
post Jan 25, 2005 - 2:24 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Hmm, this sounds nice. few things:
1. an esimate of improved bhp without a turbo.
2. an esimate of improved bhp with a turbo.
3. Would new rings be needed as well? or are they included?
4. Aproximate cost.
Thanks
post Jan 25, 2005 - 2:34 AM
doGGy
Joined Oct 28, '02
esimate of improved bhp? From What? From stock dimension Rods and Pistons? These are not for BHP, these are for strenght and reability, if you gonna go turbo, you need stronger internals, these are dedicated for this....
QUOTE(CheesyLobster @ Jan 25, 2005 - 12:24 AM)
4. Aproximate cost.
Thanks
[right][snapback]237998[/snapback][/right]
post Jan 25, 2005 - 2:58 AM
CheesyLobster
Joined Jul 19, '04
QUOTE(doGGy @ Jan 25, 2005 - 7:34 AM)
4. Aproximate cost.
Thanks
[right][snapback]238000[/snapback][/right]
Thats what I thought. But from a better compresion ratio? Does that not add power?
post Jan 25, 2005 - 3:37 AM
doGGy
Joined Oct 28, '02
Yes, they will, you will gain somthing about 10-15 hp at most if everything done right....
If you want pistons, then get GZE pistons, you will have higher CR with them..
QUOTE(CheesyLobster @ Jan 25, 2005 - 12:58 AM)
4. Aproximate cost.
Thanks
[right][snapback]238001[/snapback][/right]
post Jan 25, 2005 - 6:32 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
if you increase your CR do you not also have to adjust your timing maybe fuel management and run higher octane gas??
post Jan 25, 2005 - 6:41 AM
doGGy
Joined Oct 28, '02
Yes, you have to.
Period. We are talking about Rods and Pistons custom made, not about CR and other stuff..
QUOTE(van95st @ Jan 25, 2005 - 4:32 AM)
[right][snapback]238037[/snapback][/right]
post Jan 25, 2005 - 12:26 PM
d3monc3lica
Joined Aug 19, '04
From Maine
doGGy Posted Today, 11:41 AM
  Yes, you have to.
The Dogfather has spoken..
post Jan 25, 2005 - 2:48 PM
yes doggy i do know how to lower it with the 4agze pistons wink.gif 2mm headgasket should do the trick wink.gif
but i'm thinking of getting these for an N/a application since i have to relace rings
post Jan 25, 2005 - 3:04 PM
doGGy
Joined Oct 28, '02
If you gonna go N/A route, then this will be the best bang for the $. Get some ITb's, good cams, fuel managment and you will gain more then 20 hp for sure.. But higher octane will need to be used..
QUOTE(playr158 @ Jan 25, 2005 - 12:48 PM)
[right][snapback]238147[/snapback][/right]
post Jan 25, 2005 - 3:10 PM
yea higher octane is a must i know from racing motorcycles but ITB are a no for me cause well i just can't go that far but i'm probably goin to see if i can get some 82mm+ 4agze pistons since the stock is 81mm bore
and up the bore a little bit with probably a greddy emanage since they are normally easy to find
5 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 27th, 2024 - 3:42 PM
