> ST205 questions
post Jan 23, 2005 - 1:50 PM
dofbft
Joined Jan 23, '05
From SC
Got some newbie questions:
GOt a 1994 Celica
have a ST205 celica engine bought through somone that shafted me on engine harness and ecu.
Trying to get info on what harness, what tranny exactly I can buy to just get it and get it in the car and be done with the swap.
-the car is not a gt,so I am guessing I need the 5sfe tranny or mr2 turbo??
-where can I buy a harness and ecu for this engine, do the ST205 come with mafs also?
-Thanks for any help on these quesions...
This post has been edited by dofbft: Jan 23, 2005 - 2:05 PM
post Jan 23, 2005 - 2:49 PM
Mr_E
Joined Nov 16, '04
From UK
OK
If you have a Celica ST, the engine won't fit the motor mounts. It's not a huge problem, but some fabrication will be required.
It should bold up to a Celica or MR2 transmission. The late spec MR2 is preferable as it has a LSD.
3rd Gen 3S-GTE has a MAP, not a MAF.
With no wiring harness, you're in for an utter bitch of a job I suspect.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Jan 23, 2005 - 4:50 PM
dofbft
Joined Jan 23, '05
From SC
ok ,where are the map sensors located,yeah motor mounts are not an issue, ok I will get celica 5sfe tranny. hmmm no luck on finding an harness or ecu anywhere??
post Jan 23, 2005 - 5:12 PM
do some searching there is info and parts all over the place.
www.mr2oc.com
www.gt4oc.com
alltrac.net
allwheelmotion.com
This post has been edited by Supersprynt: Jan 23, 2005 - 5:30 PM
post Jan 23, 2005 - 6:20 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
no harness or ECU,
it will be easier to go with some kinda of aftermarket EMS than to replicate the stock harness
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 23, 2005 - 7:48 PM
perry190
Joined Nov 18, '04
From UK
the map sensor is located towards the left side of the bulkhead (opposite side to ignitor pack)
post Jan 24, 2005 - 4:05 AM
Rjb23
Joined Feb 8, '04
From KY
Uhmm I think he wants to know where he can find a 3sgte harness and ecu.
Lo-Fi Version Time is now: November 24th, 2024 - 3:17 AM
