> alarm 12v+, where?
post Jan 23, 2005 - 8:28 PM
Hanyo
Joined Aug 16, '03
From Bay area
where do you guys draw the power for your car alarms? Currently I just have a wire running directly to the battery. But now i'm thinking that wire would be easy to disconnect if someone tired to steel the car.
So where do you guys draw power from?
post Jan 23, 2005 - 10:11 PM
The constant power wire at the ignition harness will work.
post Jan 23, 2005 - 11:47 PM
Hanyo
Joined Aug 16, '03
From Bay area
but would that be kinda risky. drawing power from the stock wires harness
post Jan 24, 2005 - 12:34 AM
It's slighly risky. The safest way to wire would be a fused wire from the battery like you have now. But since you want to change your setup, the ignition harness is really the safest place to get +12 volts from. An alarm doesn't draw much power, and the circuit is fused anyway, so you should be fine.
Lo-Fi Version Time is now: February 17th, 2025 - 9:57 PM
