Cracked Piston Ring?, Need some Help |
Jan 24, 2005 - 7:18 PM |
Enthusiast Joined Oct 13, '03 From Dandridge, Tennessee Currently Offline Reputation: 0 (0%) |
My celica is burning a little oil and it only does it when I first start my car off (a little poof) and when I down shift or when I shift at High RPMs. I've been driving my car like an old lady latly to prevent it from getting worse so I need to know. Did I crack one of my piston rings? if so how can I get it checked and how much money would it cost?
Thanks, -Brandon -------------------- |
Jan 24, 2005 - 7:30 PM |
Enthusiast Joined Jul 24, '04 From Va Currently Offline Reputation: 0 (0%) |
Its not a cracked ring it is most likely valve stem seals. They are notorious for going on 5SFE's. As far as a shop it might be pricy. I'd just make sure its filled with oil and keep driving it till it blows up(which shouldnt be soon).
Jan 24, 2005 - 7:31 PM |
I dont think it would be cracked. Norm when the are cracked u loose the piston. My guess is there just warn. I have the same problem, i burn small amounts of oil over time. Try getting rislone, its a thickner agent, that should help.
Jan 24, 2005 - 7:38 PM |
ok thanks, I will go look for some rislone, although I've never heard of it.
Jan 24, 2005 - 8:11 PM |
QUOTE(Redline_Racer @ Jan 25, 2005 - 12:38 AM) ok thanks, I will go look for some rislone, although I've never heard of it. [right][snapback]237833[/snapback][/right] u should be able to find it at any auto center. It was only like $3 too. I noticed i dont burn any oil for the first 2500 miles i drive after i do an opil change with it. |
Jan 24, 2005 - 9:10 PM |
there isn't a chance of burning up my engine by using that thicker agent is there?
Jan 24, 2005 - 11:31 PM |
Just test your compression if you're afraid for your piston rings.
-------------------- "It's ok to be naked girl... I'm an artist!"
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:55 PM |
