> shopping list, stuff i bought already
post Feb 1, 2005 - 11:49 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
ive just spent a **** load of money on stuff for my car. here is the list
1. turbonetics t3/t4 60' trim turbo - 706 dollars
2. sard 800 cc side feed fuel injectors - 550 dollars
3. slotted rotors and brake pads - 150 dollars
5. Extended Clutch Slave Cylinder Pushrod $24.00 USD
6. Shift Cable Bushing Kit- BIG Toyota $28.00 USD
7. Stainless Clutch Hose ST165, ST185 Celica AllTrac $55.00 USD
8. Shifter Base Bushing Kit- Toyota $28.00 USD
9. 4 used 17' tires - 80 dollars , little mistake i made
as a result, iam gonna be selling my ct20b ,after i rebuild it, soon on ebay. iam gonna send it to ats and from ats its goes straight to the buyer.
also, my stock 550cc injectors will be on ebay soon too... as soon as my 800cc are on, those go on e-bay.
mina
post Feb 2, 2005 - 1:50 AM
Fox-N-It2
Joined Jul 24, '04
From Va
You forgot the standalone......unless you already got it.
post Feb 2, 2005 - 3:55 AM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
already got ... sds efi www.sds.com
i got standalone, wiesco pistons, fmic, underdrive pulley, water injection... and some decent axels...
mina
post Feb 2, 2005 - 8:12 AM
how much for your CT20B?
And why did you pay $28 for bushing kits? They're all over ebay and MR2OC for <10. I got mine for $3 (just the cable not the base).
This post has been edited by Supersprynt: Feb 2, 2005 - 8:13 AM
post Feb 2, 2005 - 10:12 AM
jgreening
Joined Jan 17, '04
From Illinois
The one's for $10 are not solid brass. Even the guy that makes them acknowledges that they are not the same. Looks like a good product though. For $18 why mess around? I bought the speed-source (twosrus) ones too.
shifter bushing replacements
post Feb 2, 2005 - 10:13 AM
jgreening
Joined Jan 17, '04
From Illinois
Why did you get a 60 trim t3/t4 instead of a 50 or 46? You wont be at full boost until almost 5000 rpms. Should be good for drag though...
post Feb 2, 2005 - 12:35 PM
FallenHero
Joined Dec 26, '02
From Alabama
because he's making 300+whp. wink.gif gotta get those big boos numbers.
post Feb 2, 2005 - 2:09 PM
jgreening
Joined Jan 17, '04
From Illinois
Also, you might want to consider a new fuel rail and fpr with those mods.
post Feb 2, 2005 - 2:44 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
i got the side feed injectors so i can avoid a new fuel rail... and whats an fpr... fuel pressure regulator... i got a standalone, so i dont think i need that...
and yeah, i got the big turbo for drag and high power output, the car is already a mission to get out the hole... slow spooling is not something iam really afraid of.
as for the ct20b, ill sell it for 150 plus shipping, ats said they would rebuilt it for about 375.... i can ship it to them or i can ship it to you , whatever you want...
mina
This post has been edited by XXX_Mina: Feb 2, 2005 - 2:52 PM
post Feb 2, 2005 - 2:59 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
how much more power u think your going to get from this setup
post Feb 2, 2005 - 3:00 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
my goal is 500hp...
post Feb 2, 2005 - 3:03 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
add Racing Wastegate 50mm to the list 190 dollars
post Feb 2, 2005 - 3:23 PM
jgreening
Joined Jan 17, '04
From Illinois
There are limitations of the stock fuel rail with an upgraded fuel pump - especially when you are using big injectors. You might want to run a search on "fuel rail" on mr2oc.com and look for a long 5 part thread from "Wolfkatz". Interesting reading.
post Feb 2, 2005 - 3:46 PM
I'll buy the CT20b off you whenever you take it off. I'll take it first I dont have money to rebuild it quite yet nor do I have better fueling.
What exactly is wrong with it? Is it even operational?
This post has been edited by Supersprynt: Feb 2, 2005 - 3:48 PM
post Feb 2, 2005 - 3:50 PM
QUOTE(jgreening @ Feb 2, 2005 - 3:23 PM)
[right][snapback]241248[/snapback][/right]
I *thought* alot of his research was deemed kinda iffy - my next engine mod will probably be 550 injectors. Mina what do u want for the 550s?
This post has been edited by Supersprynt: Feb 2, 2005 - 3:51 PM
post Feb 2, 2005 - 4:19 PM
jgreening
Joined Jan 17, '04
From Illinois
Its not iffy on a tuned motor. If you are talking about simply increasing boost to 15psi on a stock 3sgte running off a bigger fuel pump, you will probably be fine. The problem with the stock rail is that different injectors get different amounts of fuel. However, an untuned motor will be very rich anyway so the chance of a problem is probably minimal.
However, if you tune for a 11.5 or 12.0 afr, you need to understand that on the stock rail, some of the injectors will have a significantly higher afr and some will have a lower afr. Running a higher afr in any cylinder risks detonation to THAT cylinder so the aggregate afr reading is not very helpful. If you are tuning your engine, there are two wise choices when running an upgraded fuel pump:
1. tune rich
2. buy an upgraded fuel rail
post Feb 2, 2005 - 4:47 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
So your trying to get 500hp out of the stock block and internals? Or did you already mod those?. Also your running a st205 correct. And how will the celica handle traction with more the 300hp?
post Feb 2, 2005 - 4:55 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
i got the water injection to fight detonation.... hopfully the fuel rail on the 3rd gen motor is upgraded from the 2nd gen or something...as for the injectors, iam thinking 250 if you get them with the turbo... plus whatever shipping costs... this way i got money for my springs and shocks....
the turbo is okay, it just leaking oil because of a bad turbo seal...i turned on the car the other day and drove it for a second and it was working fine... just leaks oil.
mina
This post has been edited by XXX_Mina: Feb 2, 2005 - 5:00 PM
post Feb 2, 2005 - 5:02 PM
jgreening
Joined Jan 17, '04
From Illinois
doh...I forgot you had a 3rd gen. It is better from what I have read. I don't know how much.
post Feb 2, 2005 - 8:49 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
add new power antenna for 50 to my list...
and 46 mm external wastegate 155
someon check this wastegate out and see if its any good
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33742
and also these injectors, are these direct replacement
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...TRK%3AMEWN%3AIT
mina
This post has been edited by XXX_Mina: Feb 2, 2005 - 8:52 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 10:43 PM
