> lambo door owners
post Feb 4, 2005 - 3:12 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Having a hard time getting in your car? Door doesn't open up enough? I was wondering if using a longer gas strut and either cuting the mounting tab off or tapping and re-threading the mount a bit higher would work. i don't see why not, and i know this company that makes custom gas struts any strength, length and stroke. Anybody know how powerful the gas struts are?
post Feb 7, 2005 - 1:55 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
Having a hard time getting in your car? YES!
Door doesn't open up enough? YES!
QUOTE(madmods Posted Feb 4 @ 2005 - 2:12 AM )
The struts are strong, if you don't take them off before you take the hinges off your car then you will see this. I couldn't close mine for the first couple days with out really leaning in to it. The only problem that I see about cutting the mounting tab off or tapping and re-threading is if there would be enough room inside the fender.
-Brad
01 a4: daily
post Feb 7, 2005 - 6:49 PM
SoundSlut_dotcom
Joined Feb 16, '03
i get in and out fine. i think the strut supports 175 lbs.. ? i got 2 on each door..
im a avg size guy.. 5'10 190
Lo-Fi Version Time is now: November 28th, 2024 - 5:59 AM
