> whats the deal with cruise control?
post Feb 5, 2005 - 1:18 PM
qban537
Joined Jan 27, '05
From miami
ive seen a couple of threats that it doesnt work ....that it doesnt work when the car is cold ..etc...so last night i tried it, car was cold according to the gauge and indeed i couldnt get it to work ! but it has worked before ...
post Feb 5, 2005 - 1:24 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(qban537 @ Feb 5, 2005 - 10:18 AM)
[right][snapback]242398[/snapback][/right]
im pretty sure it will only work above a certain speed
it also has a vaccuum reference, to know what the load on the engine is and when to let off the gas or give it more gas
vaccuum charictaristics are different when the car is cold. wait five minutes for it to warm up, and try using its at speeds higher than 40mph
This post has been edited by 97sccelica: Feb 5, 2005 - 1:25 PM
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 5, 2005 - 1:27 PM
qban537
Joined Jan 27, '05
From miami
i was going 70 on the highway for like 15 mins car dont warm up...
post Feb 7, 2005 - 12:02 AM
Jaws4God
Joined Mar 27, '04
i've had some problems with my cruise control... sometimes it'd work fine.. other times, it would work, but be very irratic. It would accelerate pretty heavily then let off, the accelerate, then off... etc... wouldn't stop unless i turned the cruise control off... i still haven't figured it out tongue.gif
post Feb 7, 2005 - 8:10 AM
QUOTE(qban537 @ Feb 5, 2005 - 1:27 PM)
[right][snapback]242406[/snapback][/right]
When you say warm up, do you mean blow up? Because I leave my car idle for 15mins its warm, so 70 on the highway for 15mins, your car is warm, impossible not to be.
post Feb 7, 2005 - 8:26 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
Word of advice about warm ups. If you want your Celica to last, warm it up daily. Give it at least 2 minutes on a normal day and longer if it's cold. Mine is up to 246,000 miles, and I'm sure between that and the religious 3k mile oil changes, that is why I'm on the original engine with no overhaul, and no performance probs. Still getting 28 or 29 mpg, too.
post Feb 7, 2005 - 12:06 PM
Jaws4God
Joined Mar 27, '04
QUOTE(94GT @ Feb 7, 2005 - 1:26 PM)
[right][snapback]242908[/snapback][/right]
Good Advice biggrin.gif I usually try to let mine warm up before i get on it.. wink.gif However sometimes if in a hurry i don't. frown.gif But i hope my engine lasts into the 200 k miles
post Feb 7, 2005 - 1:05 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(Supersprynt @ Feb 7, 2005 - 5:10 AM)
[right][snapback]242904[/snapback][/right]
broken thermostat?
sounds like it to me.
post Feb 7, 2005 - 1:20 PM
whose?
post Feb 7, 2005 - 8:31 PM
qban537
Joined Jan 27, '05
From miami
ive been meaning to check the thermostat , i will get that done when i do whatever im going do with the engine (rebuilt) or swap for a 3sge ..the temp is very wierd if its cold outside and on the highway temp WONT go up ..no way no how ...and i live in miami so theres no way it can be THAT cold outside.....btw do you need a new ECU for the 3sge swap?
post Feb 7, 2005 - 8:55 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(Supersprynt @ Feb 7, 2005 - 10:20 AM)
whose?
[right][snapback]243013[/snapback][/right]
the guy that drives on the freeway and the car still doesnt warm up. not you.
Lo-Fi Version Time is now: February 22nd, 2025 - 1:56 PM
