> Header and sp1, It wont pass smog will it?
post Feb 7, 2005 - 1:36 PM
urbandork
Joined Jul 16, '04
From Los Angeles
will a header with a greddy sp1 on it pas smog?
post Feb 7, 2005 - 4:28 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The header will fail visual inspection unless it is a CARB certified header. The exhaust won't affect much so long as the CAT is still there.
post Feb 7, 2005 - 4:33 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
California is definitely the Smog Nazi of America, but I thought there were some locations you could find that didn't visually inspect?
post Feb 7, 2005 - 6:31 PM
urbandork
Joined Jul 16, '04
From Los Angeles
well if n e thing ill just keep the stock stuff and throw it back on. Perhaps ill c if i can get the stock heat sheild and if iget lucky ill get a guy who doesnt lok to closly lol.
post Feb 7, 2005 - 6:39 PM
erics1one
Joined Aug 27, '04
I've never got tested in Cali, but I find it hard to believe that they'll take the time to remove heat shields and parts to inspect every car and trucks header certification.
I'm sure someone will post some experiences they've had...sooner or later.
post Feb 8, 2005 - 2:28 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(erics1one @ Feb 7, 2005 - 11:39 PM)
[right][snapback]243169[/snapback][/right]
Umm... it's not exactly hard to tell if the engine is running an aftermarket header or not. If you think a heat shield can cover it up... well... haha... As far as experience goes... considering I work at a shop that does smog checks... I'd say it doesn't get more detailed than that... wink.gif
post Feb 8, 2005 - 3:02 AM
Hanyo
Joined Aug 16, '03
From Bay area
hey Kwanza26,
post Feb 8, 2005 - 8:31 AM
like kwanza said...it wont pass visual #1...and the header eliminates your primary cat..even if you pass visually, you may not pass the sniff test...id say just save your stock manifold and primary cat, and use anitseaze compound on all the threads when you install the header so you'll be able to get it off and on for inspection. wink.gif
post Feb 8, 2005 - 11:06 AM
erics1one
Joined Aug 27, '04
QUOTE(Kwanza26 @ Feb 8, 2005 - 12:28 AM)
[right][snapback]243320[/snapback][/right]
Well sure its quite obvious that someone is riding an aftermarket header, but aren't some aftermarkets still CARB certified? So you'd still need to look for the certification.
I don't know where this certification is normally posted (which is why I'm asking). Are they all located in a clear line of sight?
Thanks Kwanza
post Feb 8, 2005 - 4:44 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(erics1one @ Feb 8, 2005 - 4:06 PM)
Thanks Kwanza
[right][snapback]243399[/snapback][/right]
It's labeled right on the header... usually along with the manufacture's stamp. Some companies, such as TRD, will require you to send in proof of purchase and then they'll send you a little card or something with CARB numbers on it.
Lo-Fi Version Time is now: February 22nd, 2025 - 5:52 AM
