> 7afe on the way out
post Feb 8, 2005 - 11:40 AM
Rjb23
Joined Feb 8, '04
From KY
Well today I lost compression in one of my cylinders I believe. If my engine is under 1800 rpm's and in gear it shudders, but if its above that it runs fine. It just started doing this today. How long can I drive it like this before it blows? I plan on getting a 3sgte swap during spring break which is the 3rd week in march will it last that long?
post Feb 8, 2005 - 12:03 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
There are other things that could cause that too. A compression test should explain a lot.
post Feb 8, 2005 - 2:13 PM
Rjb23
Joined Feb 8, '04
From KY
Well, I think it is a ring, because at high rpm's it runs fine, and it happened over night. I let the oil get to low and after put more oil in it runs much better but still noticeable, under acceleration. Baiscally it feels like, being in to high of a gear for the speed I am going.
As long as it lasts me till spring break or so, I will be happy. That is when I am swaping the 3sgte in.
post Feb 8, 2005 - 9:25 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
QUOTE(Rjb23 @ Feb 8, 2005 - 2:13 PM)
[right][snapback]243463[/snapback][/right]
dude im right in there with u...my ****ty 7afe is dying slowly...burning oil and gas like a mofe...i want a 3sgte so bad...how much r u paying for urs? its just so expensive and hard to do in an ST how r u doin it? urself? r u using gt tran or mr2 and u gettin new axles and stuff?? id love to know how u r doin it
post Feb 8, 2005 - 11:00 PM
Rjb23
Joined Feb 8, '04
From KY
Im having it installed. And the frame in the st is the same frame as the gt so its not any more difficult, just use the gt motor mounts.
post Feb 8, 2005 - 11:26 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
QUOTE(Rjb23 @ Feb 8, 2005 - 11:00 PM)
[right][snapback]243693[/snapback][/right]
are u a million% positive on that becuz ive heard u need new axles to match if u use the mr2 tranny and new axles if u used the gt tranny
post Feb 9, 2005 - 12:34 AM
exxtractor
Joined Mar 31, '03
From BC
Try some engine restorer, can't hurt. I've noticed less oil consumption. Maybe it will buy a litte time.
Engine Restorer
post Feb 9, 2005 - 5:22 AM
Rjb23
Joined Feb 8, '04
From KY
I may try that, I'm starting to thing its the fuel filter because the engine runs smooth at idle and with no load on it. But under acceleration it acts like its not getting gas, then it gets gas and takes off.
As for the axles yeah you have to change axles, I beleive there is a site that shows how to do the st swap. Its not difficult, and not much different than the gt swap.
Lo-Fi Version Time is now: November 23rd, 2024 - 5:40 PM
