> vert problems, HELP
post Feb 9, 2005 - 12:33 PM
juBz86
Joined Aug 18, '04
From NJ
ok so as the topic says. i'm having trouble with my vert. i cant open it electicly only manually. one side seems to be working fine but the otherside doesnt open or close making the whole thing not work.
if its down it wont even move but i hear the motor working. and when it closed it works sometimes. what could be the problem?? the hinges??
post Feb 9, 2005 - 12:36 PM
shid
Joined Jan 8, '04
From LA
Naw, ur motors dead. I could "hear" mine working too. It's gears are shot, or whatever. But you need a new motor for that side
300 bucks
post Feb 9, 2005 - 12:40 PM
juBz86
Joined Aug 18, '04
From NJ
wat about install? can i do it myself or do i have to take it 2 a shop? how much would it cost for a shop to do it??? thanx
post Feb 9, 2005 - 12:47 PM
shid
Joined Jan 8, '04
From LA
post Feb 9, 2005 - 12:57 PM
juBz86
Joined Aug 18, '04
From NJ
how hard is it?? would it just involve unbolting the old motor, unplug old connections and reconnect everything? and where is it located?
post Feb 9, 2005 - 1:02 PM
shid
Joined Jan 8, '04
From LA
Under the panels, if you want I can scan the chilton manual pages for it tonight, its decently easy (sorry I was so brief previously, at work)
post Feb 9, 2005 - 1:15 PM
juBz86
Joined Aug 18, '04
From NJ
o ok thanx it would be really helpful. what is the specific part that i need? wat do i ask for from toyota?
post Feb 9, 2005 - 1:17 PM
shid
Joined Jan 8, '04
From LA
QUOTE(juBz86 @ Feb 9, 2005 - 6:15 PM)
[right][snapback]243941[/snapback][/right]
I actually haven't gotten around to installing the motor, so its still in its case, I can even take pictures of it. smile.gif
post Feb 9, 2005 - 7:57 PM
nitemare
Joined Jan 12, '03
good luck with the install! I dont recommend u doing it yourself. U have to take apart the entire back seat, side panels- just to get to the damn motor-remove window parts, etc..
I had same problem -about 3 x!! Both side motors went. I ended up buying them from the junkyard instead of paying a ripoff price off $300.. works fine..for now...the vert top is the only thing on my car that breaks--every summer-the back windows dont move up/down (replaced those stupid motors too)!...
post Feb 9, 2005 - 8:48 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(nitemare @ Feb 10, 2005 - 12:57 AM)
[right][snapback]244091[/snapback][/right]
This is an extremely easy repair to do(motor for the top), and one that the dealer will charge you big bucks. Now the side windows on a vert are a different problem, because they are hard to get to. Your also in luck, because I have a few extra motors laying around here. Pm if you are interested.
post Feb 9, 2005 - 9:52 PM
jgreening
Joined Jan 17, '04
From Illinois
Do not pick up motors out of the junk yard for the 95-97 verts. ASC used a new model in 1998 because of the problems they had with the first version.
post Feb 9, 2005 - 10:09 PM
shid
Joined Jan 8, '04
From LA
QUOTE(jgreening @ Feb 10, 2005 - 2:52 AM)
[right][snapback]244139[/snapback][/right]
Interesting info Jay; does this mean motors meant for a 98 won't fit a 97?
post Feb 9, 2005 - 10:39 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
post Feb 9, 2005 - 11:04 PM
juBz86
Joined Aug 18, '04
From NJ
thanx for all your help. it seems as have done this b4. wat are the steps (vague) in changing the motor. thanx
post Feb 9, 2005 - 11:23 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Rear seat(top half) unbolts from the trunk!
post Feb 10, 2005 - 6:49 PM
juBz86
Joined Aug 18, '04
From NJ
hey shid did u get around to scanning the page from chilton? or which manual is it? i'm thinking about picking one of them. thanx
post Feb 11, 2005 - 2:37 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(shid @ Feb 9, 2005 - 10:09 PM)
[right][snapback]244148[/snapback][/right]
I would imagine it would fit but I do not know. If I had to guess, if you buy a new motor from Toyota, you will get the upgraded one no matter what year you specify. I bet they do not even have different part numbers.
This post has been edited by jgreening: Feb 11, 2005 - 2:37 AM
Lo-Fi Version Time is now: November 28th, 2024 - 9:35 AM
