2 Pages V  < 1 2
> GT4 hood vent, question
post Feb 13, 2005 - 5:38 PM
Itchy's hood isn't stock silver, I would still have to repaint (trying to avoid that)
The technique is kinda simple, when I cut the hood I will leave notches or tabs for the vent to bolt into. The vent hole wouldn't be completely round, it would have 6 teeth.
Think of it like carving a mouth in a pumpkin,
the vent bolts to the teeth.
post Feb 13, 2005 - 5:55 PM
jgreening
Joined Jan 17, '04
From Illinois
Love the pictoral explanation! Have you tried to bend yours slightly with the curve of the hood? Does it stress the vent at all by doing that?
post Feb 13, 2005 - 5:59 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Batman722 @ Feb 13, 2005 - 5:38 PM)
[right][snapback]245550[/snapback][/right]
How about adnason's?
post Feb 13, 2005 - 6:02 PM
the vent is curved. I would assume (I hope) it's already with the curve of the hood. To test for curve, I turned it upside down, placed it on a flat surface (my coffee table), and I can rock it back and forth (see-saw). The vent seems pretty strong and there is a rubber gasket/lining all the way around the outer edge of it. I'm sure that I could make it work and I don't think it would cost too much if a body shop installed.
post Feb 13, 2005 - 6:12 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Batman722 @ Feb 13, 2005 - 6:02 PM)
[right][snapback]245561[/snapback][/right]
Interesting. I would never have guessed by pictures that the vent is curved. When you say that the vent is "strong", is it rigid or brittle like a little bending would break it? Or do you just mean "tough" so that it can hold up to a little bending?
post Feb 13, 2005 - 6:38 PM
I couldn't reallt bend it. It is strong. Here are some pics I just took
underneath full
under left side
TOP left side
hope that helps, also here is one of the vent upside down and me holding down one side, you can see the other side raised
left held down - right raised
want more biggrin.gif ?
post Feb 13, 2005 - 6:50 PM
jgreening
Joined Jan 17, '04
From Illinois
Great stuff. Thanks a bunch for all your help. I think I am going to go for it.
post Feb 14, 2005 - 10:03 PM
jgreening
Joined Jan 17, '04
From Illinois
Vent purchased today. Stay tuned for pics of Exterior 2.0.
post Feb 17, 2005 - 10:07 PM
jgreening
Joined Jan 17, '04
From Illinois
I have a new idea for installation. I think I am going to cut the hole exactly the same size as the vent. Then, I am going to take a piece of rolled steel that has a slightly larger outside diameter and a slightly smaller inside diameter and weld it to the bottom of the hood. I will then drop in the vent, mark the holes and drill.
The advantage of this over the pumpkin method is that the vent will sit down into the hood just a little to make it flush or nearly flush.
Any critiques?
post Feb 17, 2005 - 10:19 PM
becareful welding the hood. you dont want those welds to show up on top of the hood.
This post has been edited by lagos: Feb 17, 2005 - 10:19 PM
post Feb 18, 2005 - 12:31 AM
jgreening, you have a PM
post Feb 18, 2005 - 9:05 AM
Insanity-74
Joined Jan 9, '05
From Under the car
If anybody want, I can post detailed piccies of a GT4 Hood vent so that you can try to fabricate your own. I`ll even add dimensions.
post Feb 18, 2005 - 10:53 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
wheres best place to get a vent and how much is it?
post Feb 18, 2005 - 11:55 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
dealership like 35$
Team 6gc 2005
post Feb 18, 2005 - 12:08 PM
LewFX
Joined Jan 28, '05
My dealerships dont know anything about GT-4 products
post Feb 18, 2005 - 1:05 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
trick is don't tell em a thing, just print off all the part #'s without names and hand em to the guy. if he askes wut they are don't tell him. The second u say gt4 or jdm they will no even try to run them.
Team 6gc 2005
post Feb 18, 2005 - 1:28 PM
yeah just go in there with the part number....if they try to tell you that it might not come in, tell him that you know 100% that it will and to just place the order for u.
post Feb 18, 2005 - 4:21 PM
LewFX
Joined Jan 28, '05
wow your right, i emailed them the part #'s and they can get them the next day, sweeeeeeetttt...the strut bar is 86.11 - 25% coupon and im getting the GT4 hood vent for $36.44.
post Feb 18, 2005 - 7:25 PM
FORGMANN
Joined Dec 11, '04
From USA
hey,
i have a slightly bent st205 hood wi/o any trim .. bent on sides but if someone wants all the vent holes and center bump i can cut up ..
not worth shipping whole hood ..
hood is aluminum so welding to steel US hood is very difficult ..
anyway if anyone wants the holes with extra material around each to attempt making a st204 GT4 hood shoot me offer ..
otherwise hood is going to become a pop can
t
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 28th, 2024 - 10:30 PM
