Questions about engine rebuild, specifically the 7afe |
Feb 9, 2005 - 10:08 PM |
Enthusiast Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
My engine has over 200K on it and I am going to do a rebuild soon. I ahve a few questions about what I should do. I would like to eventually add a turbo so Im not sure what to actually buy. What kind of rods, pistons, etc... for the best compression. I know that a lower comp is better for boost, but If it takes me a while to add a turbo, will the lower comp be more of a hassle until I add the turbo?
Also, what is the talk of a 3 angle valve job on the head? I have an idea, but Im not exactly sure. Then theres this link of a rebuild kit Kit Is this a good thing to get? I have looked this stuff up, but I'm still in the learning stage of going about a turbo set-up. I have read it all on this site and I'm just looking for more helpful information about the engine rebuilding Jeremy This post has been edited by Jeremy1210: Feb 9, 2005 - 10:08 PM |
Feb 9, 2005 - 11:04 PM |
Enthusiast Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) |
get the kit from toyota... they are the best parts...
Feb 10, 2005 - 12:49 AM |
ebay has 7a re-build kits from toyota also. For pistons and such I would also go Toyota.
Feb 10, 2005 - 5:40 AM |
Enthusiast Joined Feb 7, '05 From Los Angeles, CA Currently Offline Reputation: 0 (0%) |
If you are going to drop the comp. then you will lose power. So if you are going to wait a while then you might want to think about this. Also if you aren't going over about 7-9 pounds of boost then you can still run stock comp. You just need to get stronger pistons so that they don't wear out sooner. Other then that go with a re-build kit from toyota or find a company that can help you out with making your own re-build kit.
Feb 10, 2005 - 6:12 AM |
this is my $.o2
from past experience on rebuilding high milage engines. I would recomend getting a shop to replace the valve stem guilds and get the cyclinder honed. This is probably a good time to get some 4ag(z)e pistions in. ( i dont know much about this so you will have to ask the gods of 6gc aka dmc doggy nik.. just to list a few) From my perspective, droping compression is as simple as getting a thicker head gasket, because there isnt much after market rods and pistions for the 7afe.. ( i know, i know.. i'm gonna get slapped for saying this.) i just got to stur up some thoughts for kwanza (and others) to straighten things out.. it will be interesting reading this post tomarrow... flame away at me guys!!!!! muahahahaha i hope this helps. btw 3 angle valve job helps increase air flow and creates a better seal on the valve seat.. hope i didnt tell you something you already know. |
Jun 26, 2005 - 4:36 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
So what was the verdict on this guys? I plan on going to a T-3 turbo at some point at leave it set at 10 ish psi..... What all needs to be re-done and what rebuild kit should i go with? BTW I have 167k on my car and engine
Jun 26, 2005 - 7:17 PM |
Pauter rods=700. 4agze pistons with a proper head gasket=3-400$
That's a grand worth right there. |
Jun 26, 2005 - 10:35 PM |
pauter rods = 715$
i wouldn't suggest the 4agze pistons really since it will give you a really high unknown cr and using a 2mm headgasket will drop it but will potentially be weaker for my setup i'm goin to look into custom low comp pistons for the 7afe so i know my cr and have strong pistons aka forged |
Jun 26, 2005 - 10:49 PM |
4ag are forged, but I agree about the compression. I was throwing that out as the economy option. But hey, if you're going with pauter rods, might as well do it right.
Jun 26, 2005 - 10:52 PM |
exactly why spend 715 on rods if your goin to goof up your pistons?
just doesn't make sense to half ass it |
Jun 27, 2005 - 11:33 AM |
damn guys that puts the engine/turbo at like 3-4k total if i'm correct in doing it the "right way"
Jun 27, 2005 - 2:03 PM |
Yea, but doning it right allows you more power than a stock 3s. Doing it cheap is leaving in the stock parts and running under ten pounds of boost. That would be enough for about 170-190whp depending on the set up. For some people though, that's just not enough.
ahem, nik. |
Jun 28, 2005 - 11:49 AM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
what can i say i want more boost -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: December 3rd, 2024 - 3:19 PM |
