New Indiglo's from the GB, they look tight |
Apr 4, 2003 - 9:02 PM |
Enthusiast Joined Jan 3, '03 From South Carolina Currently Offline Reputation: 0 (0%) |
Took me about a 1 1/2 hrs. Only because I wanted to make sure everything was perfect and I really coudn't find a good ground that satisfied me. Eventually I did, but key thing is to take your time.
Apr 5, 2003 - 1:42 AM |
If I had to do it again... 15 Minutes. Technically.... it took me two days. The engine temp gauge stuck and I had to go back in and fix it. Just wire the positive to the positive wire of the dimmer. It's closer and much easier. You can ground them anywhere you want. I was going to use the steering column bolt or the gas pedal bolt. I got lazy though and wired them both to the dimmer. Here is the wiring:
First wire is green, second is grey with a green stripe, third is grey and black. Green is the Positive, grey with green stripe is the variable that will smoke your gauges, grey and black is the ground. Easy as can be, and it takes no time at all. |
Apr 5, 2003 - 3:39 PM |
Enthusiast Joined Jan 30, '03 From Virginia Currently Offline Reputation: 0 (0%) |
Can I get some pics of those? Thanks.
Apr 6, 2003 - 12:07 AM |
can't you just believe me when I say they rock? (I lost my photo downloading program disc) I'll take pics and get them off of my brothers computer when I can.
Apr 6, 2003 - 5:41 PM |
Enthusiast Joined Nov 12, '02 From Tucson Currently Offline Reputation: 0 (0%) |
yay, I got mine in.... they look sweet, however when I turn them on blue the transformer whines??? Anyone got any ideas?....
Apr 7, 2003 - 12:01 AM |
haha, get louder exhaust like me. Mine don't get real blue anyway. |
Lo-Fi Version | Time is now: November 28th, 2024 - 1:01 PM |
