scary engine noises |
Feb 16, 2005 - 1:26 AM |
Enthusiast Joined Feb 4, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
hey guys
i wondered if someone could help me with a problem im having with the GT4 (gen3 3sgte) i noticed yesterday afternoon that it was making some uncharacteristic ticking/rattling type noises as i drove home - faint, but loud enough to hear from the cabin, and only under load at low rpms. just now, i went out and started it up, and at low revs, as i play with the throttle, it is making a noise that sounds like if you were to tap the bottom of an empty tin with a key - it makes this sound just over 1k rpm (so not at idle) and it gets higher pitched and more frequent as engine rpm's increase. its scaring me and i dont want to drive it till i figure out whats going on (for fear of making it worse). i cant quite identify where the sound is coming from - but it seems to be anywhere around the top of the motor. any ideas? if you need more info ill do what i can. PS. i tried to make a sound file with my camera, but the noise which is clearly audible over the background to my ears, gets drowned out completely on the camera. *shrug |
Feb 16, 2005 - 1:42 AM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Aftermarket intake?
It could be lifter tick? Does the Group A 3sgte have solid lifters? If so, it sounds like they need to be adjusted |
Feb 16, 2005 - 2:03 AM |
its totally stock
lifter tick - i thought that was audible at any rpms |
Feb 16, 2005 - 5:04 AM |
well i got brave enough to take it for a drive
it dissapears sorta at higher rpms like 4-5k (and below 1k rpm) the performance symptoms it is showing is the same problem i had before (missing, surging, pulling back) but MUCH worse - i was hoping was an ignition problem which i havent had time to fix yet no check engine light, but i will pull the codes (there was a 23 and a 41 in there before from god knows how long ago) cant see any smoke from where i sit (i did try) but the fumes smell much worse at idle. at the end of the drive the ticking noise went away ALMOST completely - but the performance remained terrible. |
Feb 16, 2005 - 7:26 AM |
somethings wrong, your ecu is retarding timing.
Feb 16, 2005 - 10:04 AM |
Change the plugs, wires, distributor cap and rotor and oil...See if that works first.
Feb 16, 2005 - 10:09 AM |
Enthusiast Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
Sorry for this stupid question, but what kind of fuel are you putting in?
Feb 16, 2005 - 1:29 PM |
could be anything from exhaust manifold leak, to a clutch issue.
i bought this car stethiscope from sears, it really does a great job at helping you find the source of the problem. see if you can find something like that. i had a similar strage noise coming from my engine bay, it turned out it was coming from the clutch and throwout bearing. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 16, 2005 - 1:53 PM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
QUOTE(lagos @ Feb 16, 2005 - 10:29 AM) could be anything from exhaust manifold leak, to a clutch issue. i bought this car stethiscope from sears, it really does a great job at helping you find the source of the problem. see if you can find something like that. i had a similar strage noise coming from my engine bay, it turned out it was coming from the clutch and throwout bearing. [right][snapback]246823[/snapback][/right] I had that same problem, and it ended up being the same thing. The bearing. |
Feb 16, 2005 - 9:19 PM |
98 octane fuel
a car stethescope you say... ill look around for that i hope its not anything clutch related cos man thats gonna be a pain |
Lo-Fi Version | Time is now: November 27th, 2024 - 11:41 PM |
