> Plan to pass CA emissions with 3sgte, Retarded or not?
post Feb 16, 2005 - 8:21 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
Hi, I'm planning to buy a celica with a swapped 3s-gte motor in it. I currently own a completely stock 94 celica gt. When it is time to smog the swap car can I take in the stock celica and try to pass it off for the swapped one or will they actually take a look at my VIN number etc. Wishful thinking?
post Feb 16, 2005 - 8:27 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Heh... doubtful. I wouldn't risk trying to fool a smog tech... cause if you get caught, he'll definately want to have your ass smoked...
post Feb 16, 2005 - 8:47 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
dang frown.gif well i tried guess the only way is bribery D:
post Feb 16, 2005 - 10:59 PM
Junior
Joined May 5, '03
From Toronto
pull out an injector and run mad lean. You should pass
post Feb 16, 2005 - 11:13 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
I wouldn't pass visual inspection though because of a lack of many emissions controls like the egr and whatnot. I'm thinking that the smog guys dont look that closely at your car?
post Feb 16, 2005 - 11:41 PM
i doubt the visual inspectioin gets done. these guys do like 10 cars a day, all they care about is if it passes the tail pipe sniffer and if you have a cat.
i used to worry about it... then i went to a local midas shop, they thought my car was cool, and passed it.
This post has been edited by lagos: Feb 16, 2005 - 11:43 PM
post Feb 16, 2005 - 11:42 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
lol are we talking about DMC's car hehehe
-DMC
post Feb 17, 2005 - 2:07 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(lagos @ Feb 17, 2005 - 4:41 AM)
[right][snapback]247081[/snapback][/right]
Visual inspection is mandatory... there's really no way to fool it. I mean... the tech's gotta open the hood and check various things... Unless the car is OBD2... there's really no way to do a smog without opening up the hood. It may not be as strict elsewhere... but this is CA we're talking about here...
post Feb 17, 2005 - 2:44 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
obd2 car, he plugs in the scanner
non obd2, he opens the hood, checks timing, checks EGR valve, and then runs the car.
and they do check the vin
if you wanna try something like that
buy and register an ST, then put the plates and stickers on the swapped car
when the time comes to smog, put the plates on the ST and take her in.
make sure they are the same color car
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 17, 2005 - 6:00 AM
Hanyo
Joined Aug 16, '03
From Bay area
yup that sounds like the way to do it..
post Feb 17, 2005 - 5:12 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
the sniffer is the easy part... a 3s with a good cat will pass emisions of a 5s or 7a no problem.
post Feb 18, 2005 - 9:09 PM
soltrain
Joined Aug 19, '04
From Berkeley
how did DMC do it all these years? Isn't it also the seller of the used car's responsibility to have it smogged before sale?
post Feb 18, 2005 - 9:18 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
DMC is in the military... car has texas plates cause his home of residence is in texas...
-DMC
post Feb 18, 2005 - 9:23 PM
slipgun
Joined Jun 2, '03
From Annandale VA
DMC is a smart man.
post Feb 18, 2005 - 10:45 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
-DMC
Lo-Fi Version Time is now: January 9th, 2025 - 10:07 PM
