need help on e153 swap |
Feb 17, 2005 - 8:19 AM |
Enthusiast Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) |
Hi guys,
I was wondering if anybody can tell me on what shifter cable to use on a e153 tranny swap. I've try to search for it but it came out blank. Please help... Thanks, |
Feb 17, 2005 - 12:13 PM |
GT cables work. Thats what I have. I would bet the ST205 cables would also work and, if they did, would be a better option.
Feb 17, 2005 - 12:45 PM |
thanks,
so I dont have to use theST185 cable. Does the St185 and St205 uses the same shifter cable? |
Feb 17, 2005 - 3:04 PM |
I know the 185 cables work on a 5th gen swap. I therefore assume the 205 cables will work on a 6th gen swap. I do not know whether the 185 cables will work on a 6th gen swap. There is some discussion about this in a thread I started on celicatech.com:
Celicatech.com thread re: ST205 cables This post has been edited by jgreening: Feb 17, 2005 - 3:06 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 17, 2005 - 4:41 PM |
Enthusiast Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
I have the ST205 cables, and they work and fit great.
Feb 17, 2005 - 7:48 PM |
QUOTE(sphinx @ Feb 17, 2005 - 4:41 PM) I have the ST205 cables, and they work and fit great. [right][snapback]247354[/snapback][/right] Good to know Sphinx. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 18, 2005 - 8:54 AM |
thanks,
anymore help will be appreciated... |
Lo-Fi Version | Time is now: November 27th, 2024 - 10:11 PM |
